2017-03-20 - Deepin, KDE Framework, Haskell, Python, Kernels (Stable Update)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
Hi community,
with this update we have updated most of our Kernels, added the latest KDE framework, pushed out some more Deepin packages and renewed Python and Haskell.
Please report any issues you may have with this update.
Kind regards,
Current supported Kernels
linux310 3.10.105
linux312 3.12.70
linux316 3.16.41
linux318 3.18.48 [EOL]
linux41 4.1.39
linux44 4.4.54
linux48 4.8.17 [EOL]
linux49 4.9.15
linux410 4.10.3
linux-RT-LTS 4.4.50_rt62
linux-RT 4.9.13_rt11
Package Updates (Fri Mar 17 08:15:08 CET 2017)
stable community i686: 365 new and 351 removed package(s)
stable community x86_64: 368 new and 353 removed package(s)
stable core i686: 21 new and 21 removed package(s)
stable core x86_64: 21 new and 21 removed package(s)
stable extra i686: 265 new and 257 removed package(s)
stable extra x86_64: 265 new and 257 removed package(s)
stable multilib x86_64: 20 new and 14 removed package(s)
A detailed list of all package changes can be found here.
Troubleshoot
If manjaro-system can't handle the file conflict issue with ca-certificates-utils do the following:
# pacman -Syuw                           # download packages
# rm /etc/ssl/certs/ca-certificates.crt  # remove conflicting file
# pacman -Su                             # perform upgrade
Quelle
Zuletzt geändert von Blueriver am Dienstag 21. März 2017, 14:38, insgesamt 1-mal geändert.
Re: 2017-03-20 - Deepin, KDE Framework, Haskell, Python, Kernels (Stable Update)
Perfekt wie immer!
System:    Host: dirk-pc Kernel: 4.10.3-1-MANJARO x86_64 (64 bit)
