2017-01-17 - Python, Xorg, ruby, gcc, inkscape (Stable Update)
Hatte keine Probleme.
5
71%
1
14%
1
14%
Insgesamt abgegebene Stimmen: 7
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
Buckle up, this is a huge update!
Python got updated to 3.6 and a huge amount of other packages depending on it needed to be rebuilt for that reason.
Mind that some of your packages from the AUR might also need a rebuild.
To identify these, do the stable update first and then check if libraries are still installed in the directory /usr/lib/python3.5/site-packages:
pacman -Qo /usr/lib/python3.5/site-packages
will return the packages owning such files. If this returns empty you don't need to do anything. If it returns packages from the AUR, you need to reinstall them with
yaourt -S <packagename>
With this update Xorg-server is updated to 1.19. Experience on unstable and testing branches suggests that everything was well prepared and the update should be rather uneventful.
You will be asked to remove deprecated drivers xf86-input-acecad and xf86-input-joystick. Please confirm that.
freetype2 is going to "rename" terminus-font to "Xos4 Terminus".
Please make sure to rename the font accordingly in your settings!
The update of harfbuzz is incompatible with infinality-bundle! This is a serious problem on Plasma 5 and kinit will fail!
Please consider returning to native freetype2 subpixel rendering or try the updated freetype2-infinality package from here.
New in our repos is cinnamon-sounds, a collection of the original Linuxmint system-sounds for the Mate and Cinnamon desktops.
We have new version of Inkscape (0.92), ruby (2.4) and gcc (6.3.1)
The new default manjaro-KDE themes collection Breath, again designed by @mcder3, is now almost final with: plasma5-themes-breath, breath-wallpaper, breath-icon-theme , breath-dark-icon-theme and sddm-breath-theme - a few more adjustments to the wallpaper are still in preparation.
Xreader has now added epub support, Deepin-desktop received a bugfix and some KDE apps were updated aswell.
All kernels of the 4.x series and our rt-kernels have seen new point releases.
Linux48 has been labelled End-Of-Life and will be removed in the near future. So please consider moving on to linux49, which is going to be the next LTS kernel.
Security updates include flashplugin and python-crypto.
core i686:  36 new and 35 removed packages
core x86_64:  36 new and 35 removed packages
extra i686:  714 new and 754 removed packages
extra x86_64:  714 new and 754 removed packages
community i686:  1637 new and 1620 removed packages
community x86_64:  1679 new and 1664 removed packages
multilib x86_64:  36 new and 34 removed packages
The full list of package changes can be found here.
Please give us feedback and report your findings and issues in the thread below as usual.
Current supported kernels
linux310 3.10.104
linux312 3.12.69
linux316 3.16.39
linux318 3.18.46
linux41 4.1.37
linux44 4.4.41
linux48 4.8.17 [EOL]
linux49 4.9.2
linux410 4.10-rc3
linux-RT-LTS 4.4.39_rt50
linux-RT 4.9_rt1
Quelle
Zuletzt geändert von Blueriver am Mittwoch 18. Januar 2017, 07:02, insgesamt 1-mal geändert.
Re: 2017-01-17 - Python, Xorg, ruby, gcc, inkscape Stable Update)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.9.2-1-MANJARO x86_64 (64 bit)
Revan335
Beitrag von Revan335 »
Gibt es von diesem Release ein neues ISO?
Das neue Standard Dark Theme und Kernel 4.9 LTS klingen interessant.
Dann würde ich das direkt für eine Neuinstallation diese Woche nutzen?
Gibt ja derzeit 16.10.3 und die Alpha von 17, wenn ich richtig liege.
Die Alpha ISOs sollte man besser nicht für eine Neuinstallation nehmen, richtig?
inxi
Beitrag von inxi »
Gibt es Gründe für eine Neuinstallation?  Wenn es nur um den Kernel gehen sollte:
Kernel 4.9
sudo mhwd-kernel -i linux49
Kernel 4.10
sudo mhwd-kernel -i linux410
Neuinstallationen sind bei einem RR System, wie Manjaro, eher unnötig. Vielleicht dann, wenn man das System derart verbastelt hat, dass nichts mehr läuft.
Revan335
Re: 2017-01-17 - Python, Xorg, ruby, gcc, inkscape (Stable Update)
Neue PCs und ein wegen Partition Überlauf zerlegtes. (Kein Speicher mehr) Startete deshalb nicht mehr und die Partition wurde leer angezeigt. Mit Testdisk konnte ich auch nichts mehr finden.
Benutzer 118 gelöscht
Alles bestens auf beiden Geräten.
Danke an das Manjaro-Team
m-bostaurus
Kernel: 510
Hat sich bedankt: 51 Mal
Danksagung erhalten: 12 Mal
Beitrag von m-bostaurus »
Bei mir lief auf meinem Laptop (LXQt) scheinbar alles klar, bis ich versuchte seafile zu aktualisieren, was nicht gelang. Später versuchte ich Virtualbox zu starten. Das geht aber nicht.
Wenn ich den Start im Terminal anrege, erhalte ich folgende Fehlermeldung:
"virtualbox
VirtualBox: supR3HardenedMainGetTrustedMain: dlopen("/usr/lib/virtualbox/VirtualBox.so",) failed: /usr/lib/libharfbuzz.so.0: undefined symbol: FT_Get_Var_Blend_Coordinates
An der Klippe
libharfbuzz.so.0
scheiterte auch die Seafile-Aktualisierung.
Ich fürchte, abhängig davon, ob Anwendungen auf "libharfbuzz.so.0" bzw. die Datei, auf die diese Verknüpfung hinweist, zugreifen müssen, ist vor diesem Update zu warnen. Ich warte bei meinen anderen Rechnern ab.
inxi
Beitrag von inxi »
Man kann Pakete (oder Paketgruppen) auch von der Aktualisierung ausschließen, wenn sie als fehlerhaft erkannt wurden. Hat den Vorteil, dass nicht auf das ganze Update verzichtet werden muß. Wichtig bei Sicherheitsupdates.
m-bostaurus
Kernel: 510
Als ob ich es gerochen hätte ... vorher eine Sicherung gemacht ... dennoch: Mein Rechner fährt hoch, die üblichen Infos laufen über den Bildschirm bis zum Hinweis irgendetwas mit Plymouth und dann wird es schwarz wie die Nacht.
Mittels Strg+Alt+F3 und Einloggen habe ich startx versucht, was der Rechner mit einer Fehlermeldung quittierte. Dann habe ich folgenden Befehl eingegeben:
sudo mhwd -a pci nonfree 0800
und erhilet die Antwort:
Warning: No device of class 0800 found!
Schließlich installierte ich alle Nvidia-Pakete neu. Alles ohne ein sichtbares Ergebnis. Was könnte ich ansonsten noch machen? (Würde das System gern retten statt das alte neu einzuspielen ...)
@Administrator: Falls das verschoben werden muss, bitte!
m-bostaurus
Kernel: 510
Ich bin ein wenig schlauer geworden. Vorgeschichte: Ich wollte copyq und seafile aus dem AUR aktualisieren. Die aber meckern, weil ich Pakete verwende, die nicht mehr so up to date sind. Also habe ich sie deinstalliert:
sudo pacman -Rdd freetype2-infinality-ultimate fontconfig-infinality-ultimate
und statt dessen
sudo pacman -S freetype2
installiert. Unmittelbar danach merkte ich schon, dass sich kein Terminal mehr öffnen ließ. Nach einem Neustart ging dann gar nichts mehr. Nun habe ich freetype2 deinstalliert und die beiden anderen Pakete installiert - die Kiste läuft wieder mit graphischer Oberfläche. Aber einige Pakete kann ich nicht upgraden.
Die oben genannte Operation hatte ich auf meinem Laptop mit Intel-onboard-Graphik auch gemacht - da gab es keine Probleme ... Und nun?
inxi
Beitrag von inxi »
[quote="m-bostaurus"]
Was könnte ich ansonsten noch machen? [/quote]
sudo mhwd -a pci nonfree 0300
Zuletzt geändert von inxi am Freitag 20. Januar 2017, 23:35, insgesamt 1-mal geändert.
m-bostaurus
Kernel: 510
Ja, drei und acht sollte man unterscheiden können ... Ansonsten habe ich es jetzt alles hinbekommen. Der Befehl
reichte nicht, sondern der korrekte musste lauten:
sudo pacman -S fontconfig freetype2
Dann stimmte ich dem Entfernen aller *infinality*-Pakete zu. Eine Neuinstallierung irgendwelcher Graphiktreiber war dann überflüssig. Auch nach Neustart lief das System ohne Komplikationen. Was ich schon jetzt nicht mehr weiß ist, wie ich auf die Idee gekommen bin, auch fontconfig neu zu installieren ... vielleicht, weil es im ersten Anlauf nicht gereicht hatte, freetype2 zu installieren ...
