2016-11-25 - Plasma 5.8.4, VirtualBox 5.1.10, Gstreamer (Stable Upadte)
Hatte keine Probleme.
2
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 2
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
With Plasma 5.8.4 many bug fixes went into multi screen support. Also high DPI scaling on shutdown/switch user dialogs got disabled. Additionally taking screenshots got fixed. Virtualbox 5.1.10 includes fixes for GUI, audio and several problems with host OSs. Texlive and Gstreamer got also updated. Last but not least we ship now Linux v4.9-rc6 with all extramodules building now.
Upstream packages are up till: Thu Nov 24 13:57:52 CET 2016
Report back your findings as usual ...
Update instruction
FOR SYSTEMD USERS HAVING STILL v231-1 INSTALLED, IT IS RECOMMENDED TO USE PACMAN, AS X-SESSION MIGHT GET LOST DUE THIS UPDATE. THEREFORE WE SUGGEST TO FOLLOW OUR UPDATE RECOMMENDATION . YOU CAN TRY IF FOLLOWING CMD MIGHT CRASH YOUR SYSTEM: sudo systemctl --system daemon-reexec
Check if your mirror has synced , then do the following steps to have a smooth update:
sudo pacman -Sy
sudo pacman -S archlinux-keyring
sudo pacman -Su
Troubleshoots
Information for Catalyst users
If you are using an AMD card with Catalyst it is STRONGLY RECOMMENDED to use pacman for this update!!! The new style how Catalyst works now, would be this:
Catalyst-Utils needs now three new packages: catalyst-video, catalyst-input and catalyst-server.
Catalyst-Video provides some needed drivers like Intel and Vesa, since we have some hybrid systems too
Catalyst-Input provides the needed input drivers
Catalyst-Server provides the compatible Xorg-Server
Without these packages it would be not possible to still provide Catalyst at all. So it is logical to remove conflicting packages on these AMD systems. It can be tested with a new dev-build. If there are still issues regarding Catalyst, open an issue or a new thread, so we can discuss it.
Disable random mac address for your WLAN
Use nmcli to set 802-11-wireless.mac-address-randomization to never on a per connection basis or set
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
We support now several different steam-clients:
steam-manjaro: is our definition how steam should work on Manjaro.
steam-native: is our definition how steam should be used with our native libraries
steam: is the upstream client by Archlinux
steam-native-runtime: is the addon by upstream Archlinux to use native libraries
The clients by Manjaro are better tested and prefered for Manjaro Linux. However the upstream versions might also work for you.
Reference: Archlinux wiki
Current supported kernels
linux310 3.10.104
linux312 3.12.67
linux316 3.16.38
linux318 3.18.43
linux41 4.1.34
linux44 4.4.33
linux47 4.7.10 [EOL]
linux48 4.8.9
linux49 4.9rc6
linux-RT-LTS 4.4.32_rt43
linux-RT 4.8.6_rt5
Package changes
stable community i686: 148 new and 147 removed package(s)
stable community x86_64: 167 new and 165 removed package(s)
stable core i686: 9 new and 9 removed package(s)
stable core x86_64: 9 new and 9 removed package(s)
stable extra i686: 173 new and 173 removed package(s)
stable extra x86_64: 173 new and 173 removed package(s)
stable multilib x86_64: 1 new and 1 removed package(s)
Quelle
Re: 2016-11-25 - Plasma 5.8.4, VirtualBox 5.1.10, Gstreamer (Stable Upadte)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.8.9-1-MANJARO x86_64 (64 bit)
