2016-10-23 - Manjaro 16.10 Final Release
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
Hi Community,
After several month hard work we are happy to announce Manjaro 16.10 Fringilla to the public. This is the package-wise release of our .current stable release. Install medias (Release Candidates) can be downloaded here. All the packages added with this update can be viewed here.
Some of you might have noticed the dirtyCOW issue2 which got now fixed by this update. All currently running kernels should be updated to the latest available kernels. Also read here1 about this issue and how the Manjaro Development Team has fixed it. Users of the kernel series linux314 and linux46 should update to the next higher kernel release as both of these series got removed from our repositories as they reached end of life status a while ago.
This update has more key parts to offer than our last updates. So here are some we like to mention:
Firefox got updated to 49.0.2, which fixes some issues in that series
The Gnome Desktop got updated to 3.22.1, which brings new enhancements
The Budgie Desktop is now at version 10.2.8
The Lumina Desktop is now at version 1.1
Also the MATE Desktop got updated to its latest point release of 1.16 series
On KDE side we have now Plasma 5.8.2, Framework 5.27 and Apps in version 16.08.2
Octopi got ported to alpm and we updated our plasma themes in regard of given plasma changes
VirtualBox is now at version 5.1.8
All upstream packages got updated to snapshot Sun Oct 23 19:35:45 CEST 2016.
A full release announcement of our install medias will follow, when the final ISO images got reviewed and tested. Expect them in the next couple of days depending on the testing results.
Kind regards,
Update instruction
FOR SYSTEMD USERS HAVING STILL v231-1 INSTALLED, IT IS RECOMMENDED TO USE PACMAN, AS X-SESSION MIGHT GET LOST DUE THIS UPDATE. THEREFORE WE SUGGEST TO FOLLOW OUR UPDATE RECOMMENDATION. YOU CAN TRY IF FOLLOWING CMD MIGHT CRASH YOUR SYSTEM:
sudo systemctl --system daemon-reexec
Check if your mirror has synced44, then do the following steps to have a smooth update:
sudo pacman -Sy
sudo pacman -S archlinux-keyring
sudo pacman -Su
Troubleshoots
Information for Catalyst users
If you are using an AMD card with Catalyst it is STRONGLY RECOMMENDED to use pacman for this update!!! The new style how Catalyst works now, would be this:
Catalyst-Utils needs now three new packages: catalyst-video, catalyst-input and catalyst-server.
Catalyst-Video provides some needed drivers like Intel and Vesa, since we have some hybrid systems too
Catalyst-Input provides the needed input drivers
Catalyst-Server provides the compatible Xorg-Server
Without these packages it would be not possible to still provide Catalyst at all. So it is logical to remove conflicting packages on these AMD systems. It can be tested with a new dev-build. If there are still issues regarding Catalyst, open an issue or a new thread, so we can discuss it.
Disable random mac address for your WLAN
Use nmcli to set 802-11-wireless.mac-address-randomization to never on a per connection basis or set
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.104
Linux312 3.12.66
Linux316 3.16.38
Linux318 3.18.43
Linux41 4.1.34
Linux44 4.4.27
Linux47 4.7.10 [EOL]
Linux48 4.8.4
Linux49 4.9rc2 (git-preview)
Linux-RT-LTS 4.4.27_rt35
Linux-RT 4.8.4_rt2
Package Changes
stable community i686: 764 new and 715 removed package(s)
stable community x86_64: 796 new and 748 removed package(s)
stable core i686: 51 new and 54 removed package(s)
stable core x86_64: 51 new and 54 removed package(s)
stable extra i686: 997 new and 1006 removed package(s)
stable extra x86_64: 998 new and 1006 removed package(s)
stable multilib x86_64: 36 new and 34 removed package(s)
Quelle
Zuletzt geändert von Blueriver am Montag 24. Oktober 2016, 22:05, insgesamt 1-mal geändert.
saurier
Hat sich bedankt: 61 Mal
Danksagung erhalten: 24 Mal
Re: 2016-10-23 - Manjaro 16.10 Final Release
Beitrag von saurier »
So ganz Final glaub noch nicht, oder warum heist es rc2? Aber, läuft trotzdem gut.  :D
Amber
Beitrag von Amber »
[quote="saurier"]
nö, ist schon Finale schau -->
$ lsb_release -a
LSB Version:    n/a
Distributor ID: ManjaroLinux
Description:    Manjaro Linux
Release:        16.10
Codename:       Fringilla
Daher woh ein kleines Problem bei Dir im System - stört aber nicht.
saurier
Nicht bei mir, unter dem Quelle Link steht das so. (Downloadlinks)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.8.4-1-MANJARO x86_64 (64 bit)
@leesrott
gtk Probleme kann ich nicht bestätigen
EgLe
CPU: Intel Core i7-8809G @ 8x 4.2GHz
GPU: Radeon RX Vega M GH
Kernel: x86_64 Linux 5.0.1-1-MANJARO
Desktop-Variante: KDE / Plasma
GPU Treiber: AMD VEGAM (DRM 3.27.0, 5.0.1-1-MANJARO, LLVM 7.0.1)
Beitrag von EgLe »
habe KDe-Variante.
Update geht bei mir nicht, beendet sich immer mit folgender Meldung:
Gesamtgröße der installierten Pakete:  3346,28 MiB
Größendifferenz der Aktualisierung:    30,09 MiB
(364/364) Prüfe Schlüssel im Schlüsselring                     [##################################] 100%
(364/364) Überprüfe Paket-Integrität                           [##################################] 100%
Fehler: udiskie: signature from "Ambrevar <ambrevar@gmail.com>" is unknown trust
:: Datei /var/cache/pacman/pkg/udiskie-1.5.1-1-any.pkg.tar.xz ist beschädigt (Ungültiges oder beschädigtes Paket (PGP-Signatur)).
Soll die Datei entfernt werden? [J/n] j
Fehler: Konnte den Vorgang nicht durchführen (Ungültiges oder beschädigtes Paket)
[egle@i7-core-4770 ~]$
Ist egal ob ich ja oder Nein auswähle immer das gleiche  ;D
Habe dann im Cache nach geschaut, aber die Datei existiert da gar nicht habe da nur eine udiskie-1.4.12-1-any.pkg.tar.xz....
Also habe ich dann diese mal vergeschoben, dann downloadet er zwar seine datei aber wieder die gleiche Meldung ...
Alles etwas seltsam  ;D
Zuletzt geändert von EgLe am Montag 24. Oktober 2016, 18:00, insgesamt 1-mal geändert.
MfG EgLe
Linux will Benutzer, die Linux wollen.  Linux ist nicht Windows
Machine : Intel NUC8i7HVK
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Hat sich bedankt: 15 Mal
Danksagung erhalten: 36 Mal
Beitrag von linuxkumpel »
Zuletzt geändert von linuxkumpel am Montag 24. Oktober 2016, 19:41, insgesamt 1-mal geändert.
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Danksagung erhalten: 563 Mal
Hallo EgLe,
probiere mal
[quote="EgLe"]
Kann ja auch nicht, wenn Du zur Frage
[quote="EgLe"]
ja sagst. Da wird sie wieder entfernt.
Aber um solche Probleme in den meisten Fällen zu vermeiden, sieh mal nach ob in der Datei /etc/pacman.conf folgende Zeile steht:
SyncFirst    = manjaro-system archlinux-keyring manjaro-keyring
und auch nicht auskommentiert ist. Ansonsten korrigieren, dann werden die Schlüssel automatisch beim Update als erstes aktualisiert.
PS. Linuxkumpel war schneller ;)
Amber
Beitrag von Amber »
[quote="saurier"]
ich schrieb ja, das Problem liegt auf deinem System. Das gab es schon mal, mir ist aber nicht mehr bekannt wie es gelöst wurde. Stört aber nicht, es läuft trotzdem.
peace
EgLe
Beitrag von EgLe »
gosia hat geschrieben:
Ja das hat geholfen  ???
gosia hat geschrieben: Aber um solche Probleme in den meisten Fällen zu vermeiden, sieh mal nach ob in der Datei /etc/pacman.conf folgende Zeile steht:
Hmm, bei mir stand da nur:
Update ist nun soweit durch nur habe ich zum Schluss noch diese Meldung gesehen, ob die schlimm ist weiß ich nicht.
( 9/12) Updating the appstream index...
AppStream-Datenpool wurde geladen, aber einige Metadaten wurden wegen Fehlern ignoriert.
Fehler: Befehl konnte nicht korrekt ausgeführt werden
PS: Also bei einem Neustart ist nun mein Desktop kaputt und ich sehe auf dem Desktop nun folgende Medlung:
Fehler beim Laden der QML-Datei: file:///usr/share/plasma/plasmoids/org.kde.desktop/contents/ui/main.qml:341:5: Desktop.SystemSettings is not a type
Zuletzt geändert von EgLe am Dienstag 25. Oktober 2016, 19:54, insgesamt 1-mal geändert.
MfG EgLe
m-bostaurus
Kernel: 510
Hat sich bedankt: 51 Mal
Danksagung erhalten: 12 Mal
Beitrag von m-bostaurus »
Habe das Update auf sechs meiner sieben Rechner durchlaufen lassen. Nur einmal gab es ein Problem mit einer fehlenden Signatur. Habe mich an den Rat von Gosia gehalten
in /etc/pacman.conf zu ändern, und alles funktionierte.
