2016-09-20 - Linux 4.8, KDE Framework 5.26, Gambas3, Mesa, Octop (Stable Update)
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
Hi community,
one week passed and we have the next update-pack for you. We have now also the latest KDE Framework 5.26 added. Kernel v4.8 got introduced with its sixth release candidate, php, haskell and gambas3 updated to their latest versions and some work went into our tools. Additionally we fixed some issues in Octopi, Pamac and updated our manjaro-tools to 0.13.x series. Please contact our dev-team if you have issues on creating Manjaro Spins with this new tool set.
Archlinux upstream fixes are now from: Tue Sep 20 07:22 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. A detailed list of package changes can be found here.
Kind regards,
Troubleshoots
Information for Catalyst users
If you are using an AMD card with Catalyst it is STRONGLY RECOMMENDED to use pacman for this update!!! The new style how Catalyst works now, would be this:
Catalyst-Utils needs now three new packages: catalyst-video, catalyst-input and catalyst-server.
Catalyst-Video provides some needed drivers like Intel and Vesa, since we have some hybrid systems too
Catalyst-Input provides the needed input drivers
Catalyst-Server provides the compatible Xorg-Server
Without these packages it would be not possible to still provide Catalyst at all. So it is logical to remove conflicting packages on these AMD systems. It can be tested with a new dev-build. If there are still issues regarding Catalyst, open an issue or a new thread, so we can discuss it.
Disable random mac address for your WLAN
Use nmcli to set 802-11-wireless.mac-address-randomization to never on a per connection basis or set
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.21
Linux46 4.6.7 [EOL]
Linux47 4.7.4
Linux47 4.8-rc6
Linux-RT-LTS 4.4.19_rt27
Linux-RT 4.6.7_rt13
Package Changes
stable community i686: 510 new and 502 removed package(s)
stable community x86_64: 537 new and 529 removed package(s)
stable core i686: 29 new and 27 removed package(s)
stable core x86_64: 29 new and 27 removed package(s)
stable extra i686: 427 new and 405 removed package(s)
stable extra x86_64: 427 new and 405 removed package(s)
stable multilib x86_64: 17 new and 17 removed package(s)
Quelle
Zuletzt geändert von Blueriver am Mittwoch 21. September 2016, 20:55, insgesamt 1-mal geändert.
Re: Linux 4.8, KDE Framework 5.26, Gambas3, Mesa, Octopi (Stable Update)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.7.4-1.1-MANJARO x86_64 (64 bit gcc: 6.2.1)
          Desktop: Xfce 4.12.3 (Gtk 2.24.31) info: xfce4-panel dm: lightdm
          Distro: Manjaro Linux
Benutzer 118 gelöscht
Bis auf ein kleines Problem mit Virtualbox alles im grünen Bereich
Lösung:
Extension Pack entfernen, neu herunterladen und wieder installieren.
Josef
m-bostaurus
Kernel: 510
Hat sich bedankt: 51 Mal
Danksagung erhalten: 12 Mal
Beitrag von m-bostaurus »
Habe zuerst meinen heiklen Desktoprechner sorgfältig gesichert und dann geupdatet - alles gut. Morgen kommt der Laptop dran. Eine kleine Verbesserung habe ich sofort bemerkt: Ich kann den Dateimanager PCManFM-qt wieder mit einer Tastenkombi Strg+h dazu bringen, die versteckten Dateien anzuzeigen oder wegzutarnen. Das ging bisher nicht.
saurier
Hat sich bedankt: 61 Mal
Danksagung erhalten: 24 Mal
Re: 2016-09-20 - Linux 4.8, KDE Framework 5.26, Gambas3, Mesa, Octop (Stable Update)
Beitrag von saurier »
Kernel 4.8 zwar installiert aber wird nicht genutzt und auch nicht auswählbar beim Starten des Systems?? Wie geht das?
Gib mal im Terminal
sudo update-grub
ein.
Neu starten, dann sollte der Kernel auswählbar sein.
LuMI
Beitrag von LuMI »
[quote="saurier"]
Kernel 4.8 zwar installiert aber wird nicht genutzt und auch nicht auswählbar beim Starten des Systems?? Wie geht das?[/quote]
Es geht wohl.
[lumi@LMSB-06 ~]$ inxi -S
System:    Host: LMSB-06 Kernel: 4.8.0-1-MANJARO x86_64 (64 bit)
           Desktop: Openbox 3.6.1 Distro: Manjaro Linux
saurier
[quote="Blueriver"]
Gib mal im Terminal
sudo update-grub
ein.
gesagt getan. nicht auswälbar beim start und das kommt dann bei inxi-s
Kernel: 4.7.4-1.1-MANJARO x86_64 (64 bit)
inxi
Beitrag von inxi »
Wie wurde der Kernel installiert?
sudo mhwd-kernel -i linux48
saurier
Klappt nun, Danke. Problem war, das Ich ja auch Linux Mint  :D noch auf dem Rechner habe. Mint gestartet, da Grub Costumizer aufgerufen und da war Manjaro Kernel 4.8....Neustart und läuft.  ???
