2016-09-13 - Xorg-Stack, Firefox, Plasma5, KDE Apps, Manjaro (Stable Update)
Hi community,
Manjaro Ellada was a great release so far. However we are already working on our next release we codenamed Fringilla. During the ongoing development we found already some things we can also push to our current stable branch.
One of the bigger changes is the switch to a newer Xorg-Stack including Xorg-Server 1.18 series. We even might adopt Xorg-Server 1.19 series real soon. Is Catalyst gone then? No, we managed to re-introduce matching packages for Catalyst drivers, so they are still working. However, we might have missed some raw edges. Please report them. Nvidia got updated to 370.28, which supports now Pascal Overclocking, PRIME Sync and PixelShiftMode.
For our KDE fans we updated all apps to 16.08 series. The first point release 16.08.1 got now added to our repositories. Plasma on the other hand is now at 5.7.4. Also LibreOffice is now at 5.2.1. Another big issue was NetworkManager. We think we have also managed that problem. Report otherwise if you still have issues with your WLAN.
Most of the browsers, like Firefox and Chromium got updated to the latest releases. This goes also for Wine, Mate, Haskell and Python packages. To round this update-pack up, we switched now to our 0.13.x series of manjaro-tools. The effort is now to provide profile-settings you can install side by side. This will improve the ability to switch between our several desktop environment configurations and enables us to provide an enhanced Net-Install ISO soon. Be tuned for the new modules we write for the installer framework Calamares.
Archlinux upstream fixes are now from: Fri Sep 9 18:31 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. A detailed list of package changes can be found here.
Kind regards,
Troubleshoots
Disable random mac address for your WLAN
Use nmcli to set 802-11-wireless.mac-address-randomization to never on a per connection basis or set
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.78
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.20
Linux46 4.6.7 [EOL]
Linux47 4.7.3
Linux-RT-LTS 4.4.19_rt27
Linux-RT 4.6.7_rt11
Package Changes
community i686: 446 new and 457 removed package(s)
community x86_64: 465 new and 475 removed package(s)
core i686: 27 new and 27 removed package(s)
core x86_64: 27 new and 27 removed package(s)
extra i686: 901 new and 920 removed package(s)
extra x86_64: 901 new and 920 removed package(s)
multilib x86_64: 22 new and 24 removed package(s)
Quelle
Re: 2016-09-13 - Xorg-Stack, Firefox, Plasma5, KDE Apps, Manjaro (Stable Update)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.7.3-1-MANJARO x86_64 (64 bit gcc: 6.1.1)
           Desktop: Xfce 4.12.3 (Gtk 2.24.30) info: xfce4-panel dm: lightdm
           Distro: Manjaro Linux
Prinz
Beitrag von Prinz »
Läuft super, auch mit Nvidia 370.28.
Manjaro 16.08 Ellada / OpenRC
Kernel: x86_64 Linux 4.7.3-1-MANJARO
DE: XFCE4 / WM: Compiz / WM Theme: Vertex-Maia
GTK Theme: Vertex-Maia [GTK2] / Icon Theme: maia / Font: Droid Sans Arabic 10
CPU: Intel Core i7-2600K CPU @ 3.8GHz / GPU: GeForce GTX 970 / 4GB / RAM: 16 GB
Alles gut, ohne Probleme.  ???
Benutzer 118 gelöscht
Bei mir nicht problemlos:
:: libdbus durch core/dbus ersetzen? [J/n]
Löse Abhängigkeiten auf...
Warnung: Entferne 'dbus' aus der Ziel-Liste, da es mit 'dbus-x11' in Konflikt steht
:: dbus-x11 und libdbus stehen miteinander in Konflikt. libdbus entfernen? [j/N]
Fehler: Nicht auflösbare Paketkonflikte gefunden
Fehler: Konnte den Vorgang nicht vorbereiten (In Konflikt stehende Abhängigkeiten)
>:D
Ein bisschen nachdenken hilft (fast) immer. Einfach alles mit Ja beantworten.
Zuletzt geändert von Benutzer 118 gelöscht am Dienstag 13. September 2016, 15:32, insgesamt 1-mal geändert.
Xirrin
Beitrag von Xirrin »
Habe auch so einem ähnlichen Fehler.
sudo] Passwort für christian:
 core                     137,3 KiB   424K/s 00:00 [######################] 100%
 extra                   1913,1 KiB   430K/s 00:04 [######################] 100%
 community                  3,9 MiB   431K/s 00:09 [######################] 100%
 multilib                 188,2 KiB   434K/s 00:00 [######################] 100%
:: libdbus durch core/dbus ersetzen? [J/n] j
:: dbus-x11 und libdbus stehen miteinander in Konflikt. libdbus entfernen? [j/N] j
:: dbus-x11 und dbus stehen miteinander in Konflikt. dbus entfernen? [j/N] j
:: xorg-server und xf86-input-aiptek stehen miteinander in Konflikt (X-ABI-XINPUT_VERSION). xf86-input-aiptek entfernen? [j/N] j
:: dbus-c++: das Entfernen von dbus löscht ein benötigtes Packet von 'dbus>=1.2.0'
OpenRC  Version
Zuletzt geändert von Xirrin am Dienstag 13. September 2016, 18:06, insgesamt 1-mal geändert.
