2016-09-02 - Xorg-Stack, Plasma5, Apps, Pamac, Manjaro-Tools (Unstable Update)
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
Hi community,
Since we managed to put out our second final review of Manjaro Ellada, we are already working on our next release we codenamed Fringilla. With this update we try to fix the known networkmanager issues, updated some kernels, Plasma to 5.7.4 Apps to 16.08, added some Haskell packages and reworked all our settings for Manjaro-Tools 0.13.5. Additionally we switched to Xorg-Server 1.18 series and re-introduced matching packages for Catalyst drivers, so they are still working.
Archlinux upstream fixes are now from: Thu Sep 1 23:59 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. A detailed list can be found here .
Kind regards,
Troubleshoots
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.103
Linux312 3.12.62
Linux314 3.14.77
Linux316 3.16.37
Linux318 3.18.40
Linux41 4.1.31
Linux44 4.4.19
Linux46 4.6.7 [EOL]
Linux47 4.7.2
Linux-RT-LTS 4.4.19_rt27
Linux-RT 4.6.7_rt11
Quelle
Re: 2016-09-02 - Xorg-Stack, Plasma5, Apps, Pamac, Manjaro-Tools (Unstable Update)
Ohne Probleme!
