[gelöst] Kodi AddOn lässt sich nicht installieren Thema ist als GELÖST markiert
Die_Kralle
CPU: Intel Core i7-4700HQ
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
Hat sich bedankt: 34 Mal
Beitrag von Die_Kralle »
neue Manjaro-Installation, neue Probleme.
inxi -Fz
  Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    BIOS: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 49.1 Wh (100.0%) condition: 49.1/77.0 Wh (63.8%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 1374 min/max: 800/3400 cores: 1: 800 2: 800 3: 800
    4: 800 5: 3400 6: 800 7: 2395 8: 1200
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB
  Display: x11 server: X.org v: 1.21.1.8 driver: X: loaded: intel dri: i965
    gpu: i915 resolution: <missing: xdpyinfo/xrandr> resolution: 1: 1920x1080
    2: 1920x1080
  API: EGL v: 1.5 drivers: crocus,swrast platforms: x11,surfaceless,device
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.7-1
    renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
Audio:
    driver: snd_hda_intel
  API: ALSA v: k6.5.3-1-MANJARO status: kernel-api
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
  IF: wlp3s0 state: dormant mac: <filter>
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
Bluetooth:
  Device-1: IMC Networks BCM20702A0 driver: btusb type: USB
  Report: btmgmt ID: hci0 state: up address: <filter> bt-v: 4.0
Drives:
  Local Storage: total: 1.6 TiB used: 12.08 GiB (0.7%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.67 GiB used: 12.08 GiB (5.2%) fs: ext4 dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2200
Info:
  Processes: 228 Uptime: 41m Memory: total: 32 GiB note: est.
  available: 30.8 GiB used: 4.03 GiB (13.1%) Shell: Bash inxi: 3.3.30
Wenn ich das Kodi-AddOn "kodi-addon-inputstream-ffmpegdirect" mittels "Software hinzufügen" installieren will, dann läuft der Build-Prozess nicht durch. (Bitte keine Diskussion über Kodi Ja oder Nein - Für mich der Beste Weg um IPTV von der Fritzbox zu schauen und TimeShift nutzen zu können)
Da der gesamte Output vom Build-Prozess für einen Foren-Beitrag zu groß ist,
habe ich den in eine Textdatei gepackt, gezippt und angehängt.
Was muss ich machen, damit der BUILD-Prozess durchläuft?
Gruß Heiko
build-error.txt.zip
(172.96 KiB) 108-mal heruntergeladen
Zuletzt geändert von Die_Kralle am Samstag 7. Oktober 2023, 12:04, insgesamt 1-mal geändert.
Re: Kodi AddOn lässt sich nicht installieren
Ohne die Datei gesehen zu haben:
sudo pacman -S base-devel
Danach nochmal probieren.
Die_Kralle
Daemon hat geschrieben: ↑Dienstag 3. Oktober 2023, 10:08 Ohne die Datei gesehen zu haben:
Habe ich vorher schon installiert, weil "kodi-addon-pvr-iptvsimple" auch nicht auf Anhieb wollte.
Bei einer kompletten Neuinstallation, denkt man doch, alles ist richtig installiert.
Gruß Heiko
Naja, in der Regel braucht man das Paket nicht. Und die, die wissen dass sie es brauchen, installieren es halt.
Wie auch immer, wie viele Zeilen hat deine Datei? Mehr als hundert? Such die passenden Stellen raus und stelle die hier rein.
EDIT:
Ich installiere mir gerade mal Manjaro, mein Linux Rechner ist auf der Arbeit.
Dann kann ich dir mehr sagen.
Die_Kralle
Daemon hat geschrieben: ↑Dienstag 3. Oktober 2023, 10:34 Wie auch immer, wie viele Zeilen hat deine Datei? Mehr als hundert? Such die passenden Stellen raus und stelle die hier rein.
17101 Zeilen
src/libavcodec/x86/mathops.h: Assembler messages:
src/libavcodec/x86/mathops.h:125: Error: operand type mismatch for `shr'
make[6]: *** [/var/tmp/pamac-build-heiko/kodi-addon-inputstream-ffmpegdirect/src/inputstream.ffmpegdirect-20.5.0-Nexus/build/build/ffmpeg/src/ffmpeg/ffbuild/common.mak:67: libavformat/adtsenc.o] Fehler 1
make[6]: *** Es wird auf noch nicht beendete Prozesse gewartet …
make[5]: *** [CMakeFiles/ffmpeg.dir/build.make:86: ffmpeg-prefix/src/ffmpeg-stamp/ffmpeg-build] Fehler 2
make[4]: *** [CMakeFiles/Makefile2:83: CMakeFiles/ffmpeg.dir/all] Fehler 2
make[3]: *** [Makefile:136: all] Fehler 2
make[2]: *** [CMakeFiles/ffmpeg.dir/build.make:86: build/ffmpeg/src/ffmpeg-stamp/ffmpeg-build] Fehler 2
make[1]: *** [CMakeFiles/Makefile2:220: CMakeFiles/ffmpeg.dir/all] Fehler 2
make: *** [Makefile:91: all] Fehler 2
    Breche ab...
Gruß Heiko
Ich hab das jetzt mal selbst probiert. Bei mir funktioniert es auch nicht.
Ich hab den unstable branch gewählt in Manjaro, in der Hoffnung dass der Fehler behoben ist.
Also es liegt an ffmpeg, da musst du wohl warten bis es behoben ist. Selbst mit ffmpeg-git, der neuesten Version, scheint es noch nicht zu funktionieren. Oder der Ersteller des Pakets von Kodi muss nachbessern.
https://github.com/daiaji/inputstream.f ... t/tree/fix
Vielleicht könnt ihr damit was anfangen. Ich hab es nicht getestet.
Die_Kralle
der Grund für das Problem und eine Lösung gibt es hier:
https://github.com/xbmc/inputstream.ffm ... issues/253
Gruß Heiko
