[erledigt] ARandR lässt Schreibtisch verschwinden Thema ist als GELÖST markiert
Die_Kralle
CPU: Intel Core i7-4700HQ
Kernel: 6.6.5-1-MANJARO
Desktop-Variante: XFCE 4.18
Hat sich bedankt: 34 Mal
Beitrag von Die_Kralle »
[heiko@heiko-g750js ~]$ inxi -Fz
  Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
    Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: G750JS v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
Battery:
  ID-1: BAT0 charge: 52.9 Wh (100.0%) condition: 52.9/77.0 Wh (68.7%)
    volts: 14.8 min: 14.8
CPU:
  Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
    L2: 1024 KiB
  Speed (MHz): avg: 840 min/max: 800/3400 cores: 1: 800 2: 800 3: 800
    4: 1124 5: 799 6: 800 7: 800 8: 800
    v: kernel
  Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
  Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: intel dri: i965
    gpu: i915 resolution: 1: N/A 2: 1920x1080~60Hz
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2)
Audio:
    driver: snd_hda_intel
  Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
  Sound Server-1: PulseAudio v: 16.1 running: yes
  Sound Server-2: PipeWire v: 0.3.65 running: yes
Network:
  Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: wl
  Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
  IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth:
  Device-1: IMC Networks BCM20702A0 type: USB driver: btusb
Drives:
  Local Storage: total: 1.6 TiB used: 778.88 GiB (47.6%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
  ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
Partition:
  ID-1: / size: 233.38 GiB used: 66.56 GiB (28.5%) fs: ext4 dev: /dev/sdb2
  ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
    dev: /dev/sdb1
Swap:
Sensors:
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2200
Info:
  Processes: 273 Uptime: 2d 30m Memory: 30.81 GiB used: 3.91 GiB (12.7%)
  Shell: Bash inxi: 3.3.25
Wenn ich mittels "ARandR"(0.1.11-1) vom zwei Monitorbetrieb auf "Notebook Only" wechsel, dann verschwindet seit ca. 1 Monat der Schreibtischinhalt vom Bildschirm, auch der Mouszeiger ist weg. Ich muß mich dann erst abmelden und wieder anmelden, damit wieder alles da ist.
Bis vor einem Monat lief alles problemlos. Zwischenzeitlich sind ein oder zwei größere Updates gekommen. Keine Ahnung, ob damit etwas geändert wurde, dass jetzt für diesen Effekt sorgt.
Ich habe "ARandR" auch schon mal komplett deinstalliert und neu installiert - leider ohne Verbesserung.
Irgendwelche Ideen, was die Ursache sein könnte?
Gruß Heiko
Zuletzt geändert von Die_Kralle am Montag 27. Februar 2023, 20:44, insgesamt 1-mal geändert.
Hat sich bedankt: 183 Mal
Danksagung erhalten: 319 Mal
Re: ARandR lässt Schreibtisch verschwinden
Hab was gefunden, könnte helfen;
https://de.tipsandtrics.com/how-refresh ... ing-763598
Unter #5 Ist XFCE beschrieben.
Ist zwar umständlicher, aber wenn's hilft ...
Wenns funktioniert kann man das auch mit einem Starter machen. Doppelklick drauf und gut is.
Die_Kralle
xfce4-panel -r && xfwm4 --replace
Der Befehls für die Leiste - okay,
aber ein "Replace" für den Desktop - hmm
Gruß Heiko
Ich nehme an das ARandR ein GUI ist. was passiert wenn du ARandR im Terminal ausführst und dann von Monitor auf Only-Netbook wechselst, kommen da irgendwelche Errors?
Konfiguration mit arandr
arandr kann Ihre Monitore grafisch anordnen, Auflösungen ändern und ein Skript speichern, um Ihr Setup zu duplizieren. Wenn Sie 'Speichern unter' wählen, wird es standardmäßig in ~/.screenlayout/ gespeichert. Diese Dateien können dann automatisch gestartet werden. Manchmal treten Probleme auf, wenn das arandr-Skript zu früh nach der Anmeldung ausgeführt wird. Fügen Sie bei Bedarf einen Sleep-Befehl hinzu
hast du auch Scripte in ~/.screenlayout/ ...?
evtl mal hier posten.. und vielleicht mal ein neuen abspeichern und die alten löschen.
Die_Kralle hat geschrieben: ↑Sonntag 26. Februar 2023, 19:58
Was soll das hmm?! Hast dus probiert oder nicht? Bei mir funktioniert es jedenfalls.
Die_Kralle
ich habe jetzt dem Shortcut "STRG+ALT+P" einfach "xfce4-display-settings" zugewiesen und nicht "ARandR" und das scheint ohne Probleme zu funktionieren..
Gruß Heiko
