seit heute habe ich ein Problem mit Telegram.
Das Programm liegt im Autostart und startet beim hochfahren von selbst.
Vorhin kam beim starten des PC's folgende Meldung:
Hier stecke ich noch einmal den Log dazu:
[2020.06.12 09:39:59] Launched version: 2001007, install beta: [FALSE], alpha: 0, debug mode: [FALSE], test dc: [FALSE]
[2020.06.12 09:39:59] Executable dir: /usr/bin/, name: telegram-desktop
[2020.06.12 09:39:59] Initial working dir: /home/lenovo/
[2020.06.12 09:39:59] Working dir: /home/lenovo/.local/share/TelegramDesktop/
[2020.06.12 09:39:59] Command line: telegram-desktop -autostart
[2020.06.12 09:39:59] Executable path before check: /usr/bin/telegram-desktop
[2020.06.12 09:39:59] Logs started
[2020.06.12 09:39:59] Launcher filename: telegramdesktop.desktop
[20[2020.06.12 09:39:59] Connecting local socket to /run/user/1000/6da30bea435759455455572fe2a8b407-{87A94AB0-E370-4cde-98D3-ACC110C5967D}.[20[2020.06.12 09:39:59] This is the only instance of Telegram, starting server and app...
[2020.06.12 09:39:59] Moved logging from '/home/lenovo/.local/share/TelegramDesktop/log_start0.txt' to '/home/lenovo/.local/share/TelegramDesktop/log.txt'!
[2020.06.12 09:39:59] Primary screen DPI: 96.1263
[2020.06.12 09:40:00] Font: from ':/gui/fonts/DAOpenSansRegular.ttf' loaded 'DAOpenSansRegular'
[2020.06.12 09:40:00] Font: from ':/gui/fonts/DAVazirRegular.ttf' loaded 'DAVazirRegular'
[2020.06.12 09:40:00] Font: from ':/gui/fonts/DAOpenSansRegularItalic.ttf' loaded 'DAOpenSansRegularItalic'
[2020.06.12 09:40:00] Font: from ':/gui/fonts/DAOpenSansSemiboldAsBold.ttf' loaded 'DAOpenSansSemibold'
[2020.06.12 09:40:00] Font: from ':/gui/fonts/DAVazirMediumAsBold.ttf' loaded 'DAVazirMedium'
[2020.06.12 09:40:00] Font: from ':/gui/fonts/DAOpenSansSemiboldItalicAsBold.ttf' loaded 'DAOpenSansSemiboldItalic'
[2020.06.12 09:40:00] App Info: reading settings...
[2020.06.12 09:40:00] App Info: reading encrypted settings...
[2020.06.12 09:40:00] Lang Info: Loaded cached, keys: 2680
[2020.06.12 09:40:00] OpenAL Logging Level: (not set)
[2020.06.12 09:40:00] Audio Playback Devices: Internes Audio Analog Stereo
[2020.06.12 09:40:00] Audio Playback Default Device: Internes Audio Analog Stereo
[2020.06.12 09:40:00] Audio Capture Devices: Lenovo USB2.0 UVC Camera Mono;Monitor of Internes Audio Analog Stereo
[2020.06.12 09:40:00] Audio Capture Default Device: Lenovo USB2.0 UVC Camera Mono
[2020.06.12 09:40:00] System tray available: [TRUE]
[2020.06.12 09:40:00] Not using D-Bus global menu.
[2020.06.12 09:40:00] Not using Unity launcher counter.
[2020.06.12 09:40:00] App Info: reading map...
[2020.06.12 09:40:00] App Info: reading encrypted map...
[2020.06.12 09:40:00] App Info: reading encrypted user settings...
[2020.06.12 09:40:00] App Info: encrypted user settings read.
[2020.06.12 09:40:00] App Info: reading encrypted mtp data...
[2020.06.12 09:40:00] MTP Info: read keys, current: 6, to destroy: 0
[2020.06.12 09:40:00] Map read time: 13
[2020.06.12 09:40:00] TCP Error: network - Network unreachable
[2020.06.12 09:40:00] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:01] TCP Error: network - Network unreachable
[2020.06.12 09:40:01] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:01] Export Info: Destroy top bar by controller removal.
[2020.06.12 09:40:01] Using Qt tray icon.
[2020.06.12 09:40:02] TCP Error: network - Network unreachable
[2020.06.12 09:40:02] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:04] TCP Error: network - Network unreachable
[2020.06.12 09:40:04] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:08] TCP Error: network - Network unreachable
[2020.06.12 09:40:08] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:08] Config Error: Failed to get response, error: Host dns.google.com not found (3)
[2020.06.12 09:40:08] Config Error: Failed to parse dns response JSON, error: illegal value
[2020.06.12 09:40:08] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:09] Config Error: Failed to get response, error: Host google.com not found (3)
[2020.06.12 09:40:09] Config Error: Failed to parse dns response JSON, error: illegal value
[2020.06.12 09:40:09] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:09] TCP Error: network - Network unreachable
[2020.06.12 09:40:09] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:10] Config Error: Failed to get response, error: Host mozilla.cloudflare-dns.com not found (3)
[2020.06.12 09:40:10] Config Error: Failed to parse dns response JSON, error: illegal value
[2020.06.12 09:40:10] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:11] Config Error: Failed to get response, error: Host firebaseremoteconfig.googleapis.com not found (3)
[2020.06.12 09:40:11] Config Error: Failed to parse fire response JSON, error: illegal value
[2020.06.12 09:40:11] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:11] TCP Error: network - Network unreachable
[2020.06.12 09:40:11] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:11] Config Error: Failed to get response, error: Host www.google.com not found (3)
[2020.06.12 09:40:11] Config Error: Failed to parse dns response JSON, error: illegal value
[2020.06.12 09:40:12] Config Error: Failed to get response, error: Host www.google.ru not found (3)
[2020.06.12 09:40:12] Config Error: Failed to parse dns response JSON, error: illegal value
[2020.06.12 09:40:12] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:13] Config Error: Failed to get response, error: Host google.ru not found (3)
[2020.06.12 09:40:13] Config Error: Failed to parse dns response JSON, error: illegal value
[2020.06.12 09:40:13] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:14] Config Error: Failed to get response, error: Host firestore.googleapis.com not found (3)
[2020.06.12 09:40:14] Config Error: Failed to parse fire response JSON, error: illegal value
[2020.06.12 09:40:14] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:15] Config Error: Failed to get response, error: Host reserve-5a846.firebaseio.com not found (3)
[2020.06.12 09:40:15] Config Error: Bad data size 0 required 344
[2020.06.12 09:40:15] TCP Error: network - Network unreachable
[2020.06.12 09:40:15] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:40:15] Config Error: Failed to get response, error: Host www.google.ru not found (3)
[2020.06.12 09:40:15] Config Error: Failed to parse fire response JSON, error: illegal value
[2020.06.12 09:40:16] TCP Error: network - Network unreachable
[2020.06.12 09:40:16] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:42:54] TCP Error: network - Network unreachable
[2020.06.12 09:42:54] HTTP Error: network error 99 - Network unreachable
[2020.06.12 09:42:54] Skipping message, because it is already in blocks!
[2020.06.12 09:57:35] TCP Error: network - Network unreachable
[2020.06.12 09:57:35] HTTP Error: network error 99 - Network unreachable
Wenn man allerdings Telegam benutzt funktioniert es wie gewohnt.
Wem ist das auch schon einmal untergekommen?
Vielleicht hat jemand eine Idee - danke für eure Tipps und Vorschläge.
LG Lars
