[Testing Update] 2020-01-12 - Poppler, RT-Kernels, Palemoon 28.8.1
Hello community,
here is another Testing Update for 2020!
Some feature-updates:
Palemoon got updated to 28.8.1 10
More RT-Kernel updates
Some packages got rebuild against poppler 0.84.0-1. Tell us if we missed some.
The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 9, which we build on a regular basis against kde-git master packages. Also check out our current 18.1.5 ISOs 3 and give us the needed feedback. You might also want to give our latest spin 12 with NX-Desktop a try ...
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd 2. We adopted to the same standard. More and more packages will have the zst extension from now on.
Our current supported kernels:
linux316 3.16.80
linux44 4.4.208
linux49 4.9.208
linux414 4.14.163
linux419 4.19.94
linux53 5.3.18 [EOL]
linux54 5.4.10
linux55 5.5-rc5
linux419-rt 4.19.94_rt38
linux54-rt 5.4.10_rt5
Package Changes (Sun Jan 12 09:51:34 CET 2020)
testing community x86_64: 202 new and 193 removed package(s)
testing extra x86_64: 40 new and 40 removed package(s)
testing multilib x86_64: 1 new and 1 removed package(s)
Quelle
Re: [Testing Update] 2020-01-12 - Poppler, RT-Kernels, Palemoon 28.8.1
Ohne Probleme! :)
