Paket • shiboken • AUR • Fehler • build problem Thema ist als GELÖST markiert
Benutzer 468 gelöscht
Beitrag von Benutzer 468 gelöscht »
Paket • shiboken • AUR • Fehler • build problem,
[ 64%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/parser/smallobject.cpp.o
[ 66%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/parser/tokens.cpp.o
[ 67%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/parser/type_compiler.cpp.o
[ 69%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/parser/visitor.cpp.o
[ 70%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/parser/rpp/builtin-macros.cpp.o
[ 72%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/parser/rpp/preprocessor.cpp.o
[ 74%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/docparser.cpp.o
[ 75%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/doxygenparser.cpp.o
[ 77%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/qtdocparser.cpp.o
[ 79%] Building CXX object ApiExtractor/CMakeFiles/apiextractor.dir/qrc_generator.cxx.o
[ 80%] Linking CXX static library libapiextractor.a
[ 80%] Built target apiextractor
Scanning dependencies of target shiboken
[ 82%] Building CXX object generator/CMakeFiles/shiboken.dir/shiboken/headergenerator.cpp.o
[ 85%] Building CXX object generator/CMakeFiles/shiboken.dir/shiboken/cppgenerator.cpp.o
[ 85%] Building CXX object generator/CMakeFiles/shiboken.dir/shiboken/overloaddata.cpp.o
[ 87%] Building CXX object generator/CMakeFiles/shiboken.dir/generator.cpp.o
[ 88%] Building CXX object generator/CMakeFiles/shiboken.dir/shiboken/shibokengenerator.cpp.o
[ 90%] Building CXX object generator/CMakeFiles/shiboken.dir/shiboken/shibokennormalize.cpp.o
[ 91%] Building CXX object generator/CMakeFiles/shiboken.dir/main.cpp.o
[ 93%] Building CXX object generator/CMakeFiles/shiboken.dir/qtdoc/qtdocgenerator.cpp.o
[ 95%] Linking CXX executable shiboken
[ 95%] Built target shiboken
[ 96%] Running generator for 'shiboken'...
Unable to load library icui18n "Cannot load library icui18n: (icui18n: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden)"
Detecting inconsistencies in typesystem...   [OK]
make[2]: *** [shibokenmodule/CMakeFiles/shibokenmodule.dir/build.make:62: shibokenmodule/shiboken/shiboken_module_wrapper.cpp] Speicherzugriffsfehler (Speicherauszug erstellt)
make[1]: *** [CMakeFiles/Makefile2:336: shibokenmodule/CMakeFiles/shibokenmodule.dir/all] Fehler 2
make: *** [Makefile:130: all] Fehler 2
    Breche ab...
dazu habe ich folgendes gefunden,
Linux Manjaro build problem (Shiboken),
und,
Search Criteria
freue mich auf Euer Feedback !
viele Grüße
