QuelleHello i686ers!
This is another large update set which updates kernels 4.9 and 4.14 (with extramodules), systemd, KDE, LibreOffice, Haskell packages, Python modules …
Of particular note is the xorgproto transition. You will be prompted to replace several of the following packages:
This is expected, say “yes” to all.Code: Alles auswählen
bigreqsproto compositeproto damageproto dmxproto dri2proto dri3proto fixesproto fontsproto glproto inputproto kbproto presentproto printproto randrproto recordproto renderproto resourceproto scrnsaverproto videoproto xcmiscproto xextproto xf86dgaproto xf86driproto xf86miscproto xf86vidmodeproto xineramaproto xproto
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine)
Available kernels
Series Version
linux316 3.16.55
linux41 4.1.49
linux44 4.4.120
linux49 4.9.87
linux414 4.14.27
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
@philm decided it was high time that manjaro32 had some installer images so has been busy spinning Xfce, GNOME and KDE images. At this point, only Xfce works well enough to be considered for release, but that’s fine - Xfce is the most appropriate DE for any older machine. To get some wider testing before making this "fully " available, the image can be downloaded from: https://sourceforge.net/projects/manjar ... -rc2/xfce/ Be aware, 17.1.1-rc2 is built against t…
2018-03-17 - xorgproto, kernels, systemd, LibreOffice [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.12
- Hat sich bedankt: 31 Mal
