2018-02-15 - Kernels, OpenJDK 8 [Stable Update x32]
Hat sich bedankt: 31 Mal
Danksagung erhalten: 167 Mal
Hello i686ers!
This is a smaller update set which updates kernels 4.1, 4.9, and 4.14 (with extramodules) as well as OpenJDK 8.
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.49
linux44 4.4.115
linux49 4.9.81
linux414 4.14.19
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
There will be a new release as soon as I refresh myself on how to do it. :slight_smile:
Quelle
