QuelleHello i686ers!
This set of packages includes a large set of updates from upstream (thank you!) as well as new 4.4, 4.9, and 4.14 kernel versions. There are several other Manjaro-specific package updates, and for anyone running a 32-bit system with an NVIDIA GPU there’s a driver update to version 390.25 too.
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.115
linux49 4.9.80
linux414 4.14.17
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
2018-02-07 - Big upstream update, kernels, extramodules [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.12
- Hat sich bedankt: 31 Mal
