QuelleHello i686ers!
This set of package updates includes updates for Firefox 58.0.1 and Thunderbird 52.6, along with kernel updates and associates extramodules.
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.113
linux49 4.9.78
linux414 4.14.15
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
2018-01-31 - Kernels, Firefox, Thunderbird [Stable Update x32]
Themen Author - Moderator
- Kernel: 6.12
- Hat sich bedankt: 31 Mal
- Neues Foren Mitglied
Re: 2018-01-31 - Kernels, Firefox, Thunderbird [Stable Update x32]
I have benefited from reading this content a lot. I want to tell everyone.
