2018-01-25 - Firefox 58, r8168 extramodule, rust, TLP [Stable Update x32]
This set of package updates includes the new Firefox 58, an updated driver for r8168-based network devices, and a new TLP release.
You already had the new Palemoon release so you know about that already…
This set is a fairly small one. I suspect the next one will be quite a bit bigger.
Have fun!
Available kernels
Series Version
linux316 3.16.53
linux41 4.1.48
linux44 4.4.112
linux49 4.9.77
linux414 4.14.14
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Manjaro Development
What about security updates?
What about installer images?
Manjaro Development
There will be a new release as soon as I refresh myself on how to do it. :slight_smile:
Quelle
Carballal
Re: 2018-01-25 - Firefox 58, r8168 extramodule, rust, TLP [Stable Update x32]
Beitrag von Carballal »
The information I get from reading is very useful.
