Hi community,
this update is more or less the move back to Archlinux Mate-Upstream packages. It took a while for Arch to pick them up. Since upstream is again maintaining Mate, it makes not so much sense to do double work from our end.
TeXLive packages have been updated to the 2016 version. The most notable change is that the biber utility is now provided as a separate package. You can install it normally using pacman. Pacman hooks are now used in the TeXLive packages so the update will be less verbose than in past years.
Also we moved our Netbook-Kernel up a notch and updated it to v4.4 kernel series.
Archlinux upstream fixes are now from: Mon Aug 08 07:53 CEST 2016.
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Additional it would be good to test one of our preview install medias to check these changes on a fresh install.
Kind regards,
GTK3
You can install it with:
ufw
steam
find ~/.local/share/Steam/ \( -name "libgcc_s.so*" -o -name "libstdc++.so*" -o -name "lib
[html]
•Quelle
[/html]
[Unstable Update] 2016-08-08 - Mate (from Arch), Vulkan, Texlive
Themen Author - Administrator
- CPU: Intel® Core™ i7-2630QM
- GPU: Intel UHD Graphics
- Kernel: 5.6
- Hat sich bedankt: 189 Mal
