Quellephilm, post:1, topic:82823 hat geschrieben: Hello community,
Another **stable** branch update with some usual updates for you.
* Most of our **Kernels** got updated
* **Pipewire** is now at [0.3.35 ](https://gitlab.freedesktop.org/pipewire ... ses/0.3.35)
* Mozilla Software got updated: [Firefox 92](https://www.mozilla.org/en-US/firefox/9 ... easenotes/), [Thunderbird 91](https://www.thunderbird.net/en-US/thund ... easenotes/)
* The stable version of **LibreOffice** is now at [7.1.6](https://blog.documentfoundation.org/blo ... community/)
* **Pamac** is now at 10.2.0, which is again focusing on the desktop first. For mobile start pamac-manager with `--mobile` switch
* **Pacman** is now at [6.0.1 ](https://gitlab.archlinux.org/pacman/pac ... aster/NEWS)
* **Steam** client got renewed to fix current known issues
* **Systemd** is now at [249.4 ](https://github.com/systemd/systemd-stab ... 3...v249.4)
* Other regular upstream updates
Get our latest daily developer images now from Github: [Plasma ](https://github.com/manjaro-plasma/download/releases), [Gnome](https://github.com/manjaro-gnome/download/releases), [XFCE](https://github.com/manjaro-xfce/download/releases). You get the latest [stable releases](https://manjaro.org/download) of Manjaro from [CDN77](https://cdn77.com).
**Our current supported kernels**
* linux44 4.4.283
* linux49 4.9.282
* linux414 4.14.246
* linux419 4.19.206
* linux54 5.4.144
* linux510 5.10.63
* linux512 5.12.19 [EOL]
* linux513 5.13.15
* linux514 5.14.2
* linux510-rt 5.10.52_rt47
**Package Updates** (Sat Sep 11 15:48:56 CEST 2021)
* stable community x86_64: 633 new and 574 removed package(s)
* stable core x86_64: 38 new and 38 removed package(s)
* stable extra x86_64: 531 new and 597 removed package(s)
* stable kde-unstable x86_64: 376 new and 376 removed package(s)
* stable multilib x86_64: 21 new and 21 removed package(s)
A detailed list of package changes can be found [here ](https://lists.manjaro.org/pipermail/man ... 41859.html).
[Stable Update] 2021-09-16 - Kernels, Steam, Pipewire, Firefox, Thunderbird, Pamac, Pacman
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 153 Mal
- CPU: Intel Core i7-9750H
- Desktop-Variante: Cinnamon
- GPU Treiber: NVIDIA
- Hat sich bedankt: 35 Mal
- Danksagung erhalten: 47 Mal
Re: [Stable Update] 2021-09-16 - Kernels, Steam, Pipewire, Firefox, Thunderbird, Pamac, Pacman
Diesesmal gab es leider einige Probleme nach dem Update. Bei mir läuft Manjaro mit Cinnamon. Folgendes ist mir auf die Schnelle aufgefallen:
Leider ist auch Firefox 92 nicht mit dabei, oder habe ich da was falsch verstanden.
- Keyring Probleme werden nach dem Update angezeigt.
- Nvidia Treiber geht nicht mehr.
- VirtualBox läuft nicht mehr.
- Kernel: 6.1
Hallo ManTuxer,
zu deinem Problem Nr.1 hat Philm folgendes geschrieben.
Da bei mir keines der Probleme besteht, kann ich sagen das es bei mir ein erfolgreiches Update war.
You might have issues to install this update by missing Maintainers keys. A possible solution might be:
sudo rm -r /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate manjaro
sudo pacman-key --populate archlinux
sudo pacman -Syvv manjaro-keyring # just to test for key-problems, as this would fail
However, we recommend to remove the signatures of the failed packages in /var/cache/pacman/pkg/ and get the replaced ones from the Build-Server:
sudo rm -v /var/cache/pacman/pkg/*.sig
sudo pacman -Syvv
Bei mir wurde Firefox 92 installiert.
[2021-09-16T19:33:57+0200] [ALPM] upgraded firefox (91.0.2-1 -> 92.0-1)
[2021-09-16T19:33:57+0200] [ALPM] upgraded firefox-i18n-de (91.0.2-1 -> 92.0-1)
Danke @Blueriver. Ich bin unendlich dankbar.
Nach dem ausführen der Schritte von Philm wurden mir viel mehr Updates angezeigt, auch Firefox 92 war dabei, und das Update lief fehlerfrei durch.
Jetzt bin ich auf dem neuesten Stand und alles Funktioniert.
Obsidian aus dem AUR Repo zeigte nur noch eine Fläche wie eben das System Thema vorgab. Bei mir war sie schwarz - dürfte irgendwie an Electron 15 liegen.
Habe Obsidian dann aus dem Flatpak installiert - läuft.
Positiv: Unter dem Suchfenster von Pamac 10.2.0 erscheint jetzt zusätzlich eine Textliste der mit der Suche übereinstimmenden Suchbegriffe. Die Menüs springen beim Verkleinern des Fensters jetzt auch nicht mehr wie wild hin und her und im Vollbildmodus wird jetzt endlich ein zweispaltiges Layout genutzt. Die bereits angekündigte Trennung von Pamac in Desktop und Mobile war ein Schritt in die richtige Richtung.
- Erfahrenes Foren Mitglied
- CPU: AMD Ryzen 5 3600
- GPU: AMD ATI Radeon RX 6600XT
- Kernel: 5.19
- Desktop-Variante: Plasma
- GPU Treiber: amdgpu
- Hat sich bedankt: 5 Mal
- Danksagung erhalten: 5 Mal
Mein Problem ist ein wenig diffus. Die Mausgeschwindigkeit hat sich sehr unangenehm erhöht.
In Pasma habe ich das über die Einstellungen gefixt. Im sddm beim Anmelden ist es immer noch.
Ich weiß allerdings nicht wann es aufgetreten ist, mit dem umstellen auf den 5.14-er Kernel oder mit dem letzten Update.
Hat jemand eine Idee?
Auch Pipewire musste gefixt werden.
Grüße aus dem Saarland
Frank
Frank
- CPU: --
- GPU: --
- Kernel: --
- Desktop-Variante: --
- GPU Treiber: --
- Hat sich bedankt: 42 Mal
- Danksagung erhalten: 48 Mal
Mir wurde gestern angezeigt das es ein Update gibt. Heute wollte ich es starten über Terminal.
Ich bekomme ein: "Es gibt nichts zu tun" Und nun? warten auf bessere Zeiten?...
- Kernel: 6.1
Versuch es mal mit
sudo pacman-mirrors -f 5 && pamac upgrade -a
- CPU: --
- GPU: --
- Kernel: --
- GPU Treiber: --
Bingo!
Danke Blueriver. Aber was war jetzt anders als mit:
das ich normalerweise mache? Täte mich schon mal interessieren.
pamac update
Du bist damit nicht alleine. "Yesterday I got the notification in Pamac system tray that 107 updates were available, then I did refresh mirrors using Pamac and shutdown my laptop. Today I get no notification and Pamac shows everything is up to date !"
Da wurde offenbar innerhalb kurzer Zeit erneut etwas an den Spiegelservern geändert. Ich denke, das der Tipp von @Blueriver da in die richtige Richtung geht.
- CPU: --
- GPU: --
- Kernel: --
- GPU Treiber: --
Gut, Danke Manfrago,
Für alle die der englischen Sprache nicht so mächtig sind, (soll es ja geben) hier das ganze in Deutsch. Ist ja schließlich auch ein Deutsches Forum hier...
"Gestern bekam ich die Benachrichtigung in der Pamac-Systemleiste, dass 107 Updates verfügbar sind, dann habe ich die Spiegel mit Pamac aktualisiert und meinen Laptop heruntergefahren. Heute erhalte ich keine Benachrichtigung und Pamac zeigt an, dass alles auf dem neuesten Stand ist!"
- Neues Foren Mitglied
- GPU: Nvidia GTX 1050
- Kernel: linux514
- Desktop-Variante: KDE
- GPU Treiber: Intel/ Nvidia
- Hat sich bedankt: 8 Mal
Hallo an alle,
da ich mir gerade echt nicht sicher bin ob ich das Update gezogen habe kann mir bitte jemand sagen wie ich das raus bekomme? wenn ich über die Konsole "sudo pacman -Syuu" kommt bei mir immer nur ES GIBT NICHTS ZU TUN.
soweit ich es noch dunkel von früher her kenne zb von Ubuntu wurden Updates automatisch gezogen.
könnte mir da gegebenenfals helfen bitte.
grüße
grüße
- CPU: Intel Core i9-9900KF
- Kernel: 6.6 LTS
- Desktop-Variante: Gnome
- GPU Treiber: nVidia
- Hat sich bedankt: 19 Mal
Wenn du die Vermutung hast dass ein Update längst überfällig ist dann versuch doch mal den Befehl über Konsole von Bluerivers Beitrag viewtopic.php?f=13&t=3483&sid=18fabb4b6 ... c1f#p22238
Ich weiß zwar nicht was er im Detail macht, aber die Mirrorliste wird aktualisiert.
Manchmal fallen anscheinend Server aus oder sie werden später synchronisiert oder was auch immer...
Ansonsten kannst du dich z.B. auch hier etwas darüber einlesen
- Kernel: linux514
danke für den Link.zompel hat geschrieben: ↑Donnerstag 23. September 2021, 13:30 Wenn du die Vermutung hast dass ein Update längst überfällig ist dann versuch doch mal den Befehl über Konsole von Bluerivers Beitrag viewtopic.php?f=13&t=3483&sid=18fabb4b6 ... c1f#p22238
Den Befehl von Bluerivers hatte ich schon vorab getestet und es wurde mir auch wieder ausgegeben das es nichts zu tun gibt.
laut Konsole habe ich die Pacman Version 4.21.5 am laufen
