2017-05-12 - Kernels, KDE, KDE Apps, Gnome, Browsers (Stable Update)
<t>Hattet ihr Probleme mit dem Update?</t>
Hatte keine Probleme.
4
57%
3
43%
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 7
Danksagung erhalten: 167 Mal
Hi community,
this is one of our bigger updates and will bring a lot of different changes to Manjaro. It is recommended to read also some of our testing announcements depending on the topic. It is strongly recommended to do this update as a full update and not partial!. Please use pacman from a terminal for not breaking your system.
So what changed? Well, we started with Plasma5, Gnome, VirtualBox, OpenSSL, ICU, added then Nvidia, XFCE-GTK3, X-Apps, Kodi-Plugins, moved on to Firefox, X-Apps, Gstreamer, Bluez, had some Kernels, NoSystemd, Python, Haskell, then worked on Kernel, Virtualbox, Haskell, Gnome and finalized with NetworkManager, Chromium, KDE Apps, Pamac.
Most might have some issues with the OpenSSL or ICU update. We have some recommendation for some Steam Games.
So take your time with this update and ask us anything if some might go not so well for you. There will be a solution for it for sure. Please give us feedback as usual and report any issues you may see with this update.
Current supported Kernels
linux310 3.10.105
linux312 3.12.74 [EOL]
linux316 3.16.42
linux318 3.18.52
linux41 4.1.39
linux44 4.4.67
linux48 4.8.17 [EOL]
linux49 4.9.27
linux410 4.10.15
linux411 4.11.0
linux-RT-LTS 4.4.66_rt79
linux-RT 4.9.20_rt16
Package Updates (Fri May 12 17:46:31 CEST 2017)
stable community i686: 1114 new and 1090 removed package(s)
stable community x86_64: 1140 new and 1111 removed package(s)
stable core i686: 69 new and 65 removed package(s)
stable core x86_64: 69 new and 65 removed package(s)
stable extra i686: 1274 new and 1259 removed package(s)
stable extra x86_64: 1274 new and 1259 removed package(s)
stable multilib x86_64: 55 new and 51 removed package(s)
A detailed list of package changes can be found here.
Quelle
Re: 2017-05-12 - Kernels, KDE, KDE Apps, Gnome, Browsers (Stable Update)
Alles ohne Probleme!
System:    Host: dirk-pc Kernel: 4.11.0-1-MANJARO x86_64 (64 bit)
           Desktop: Gnome 3.24.2 Distro: Manjaro Linux
linuxkumpel
Kernel: 5.15 / 6.0
GPU Treiber: Intel i915
Hat sich bedankt: 15 Mal
Danksagung erhalten: 36 Mal
Beitrag von linuxkumpel »
Alles top und läuft.  ???
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft! :)
Peter
CPU: Intel Core i5-6200U
Beitrag von Peter »
Ich musste die gstreamer--good-plugins deinstallieren.
Die kamen damals entweder mit skype oder mit TeamViewer glaube ich. Mal sehen ob da was nicht mehr geht...
m-bostaurus
Kernel: 510
Hat sich bedankt: 51 Mal
Danksagung erhalten: 12 Mal
Beitrag von m-bostaurus »
Ich habe gestern Abend alle meine Manjaros aktualisiert und und den Kernel 411 gleich auch benutzt. Alles funktioniert tadellos bis auf die Lautsprecheranlage meines Desktops, die seitdem Update leise brummt, was sie meiner Ansicht nach vorher nicht tat. Auf meinem Laptop habe ich zwei Betriebssysteme (Mate und XFCE), bei denen mir Konflikte gemeldet wurden zwischen libsoup und den von Peter erwähnten gstreamer--good-plugin. Ich habe dann libsoup von der Aktualisierung ausgenommen. Danach lief das Update durch. Dank an das Manjaro-Team!
gstreamer0.10-good ist out-of-date und sollte daher besser deinstalliert werden.
Wird auch nicht mehr wirklich benötigt.
libsoup kann dann auch geupdatet werden.
m-bostaurus
Kernel: 510
Es gibt doch ernsthafte negative Folgen, und die sind massiv: Seafile (verschlüsselte Datensynchronisation) aus dem AUR funktioniert nicht mehr. "out of date".
Danke für den Hinweis auf gstreamer. Ich kümmere mich drum, wenn meine Datensynchronisation wieder läuft.
Danksagung erhalten: 578 Mal
Hallo m-bostaurus,
Blueriver hat völlig recht, gstreamer0.10 und alles was damit zusammenhängt
gstreamer0.10, gstreamer0.10-base, gstreamer0.10-bad, gstreamer0.10-bad-plugins, gstreamer0.10-base-plugins, gstreamer0.10-ffmpeg, gstreamer0.10-good, gstreamer0.10-good-plugins, gstreamer0.10-mm, gstreamer0.10-python, gstreamer0.10-ugly, gstreamer0.10-ugly-plugins, perl-gstreamer, perl-gstreamer-interfaces
sollen alle weg und durch die neueren GStreamer v1.x ersetzt werden, wenn man sie denn braucht.
https://www.archlinux.org/todo/phasing- ... reamer010/
Wie es dann aussieht, hat suska im anderen Forum gezeigt
https://de.manjaro.org/index.php?topic= ... n#msg49493
