2016-11-11 - Cinnamon 3.2, Gnome 3.22.3, KDE Apps 16.08.3, (Stable Update)
Hatte keine Probleme.
1
50%
0
Keine Stimmen
1
50%
Insgesamt abgegebene Stimmen: 2
Hi Community,
almost one week passed after our first updated of Fringilla. Now we are happy to present our next improvement of that release. We managed to release the brand new Cinnamon 3.2 series. Following changes you may expect of this new update for this desktop environment:
many changes including support for vertical panels
continued evolution of XApps
improved accelerometers support
applet updates
a new menu layout
a wide range of other updates
For our fans of KDE we released 16.08.3 applications. Also our Gnome fans get the latest mutter release, which fixes most of the known wayland issues. Last but not least we updated some of our kernels and fixed small issues in our graphical installer calamares.
Upstream packages are now from Fri Nov 11 19:49:06 CET 2016. Detailed package changes can be found here.
Update instruction
FOR SYSTEMD USERS HAVING STILL v231-1 INSTALLED, IT IS RECOMMENDED TO USE PACMAN, AS X-SESSION MIGHT GET LOST DUE THIS UPDATE. THEREFORE WE SUGGEST TO FOLLOW OUR UPDATE RECOMMENDATION . YOU CAN TRY IF FOLLOWING CMD MIGHT CRASH YOUR SYSTEM: sudo systemctl --system daemon-reexec
Check if your mirror has synced , then do the following steps to have a smooth update:
sudo pacman -Sy
sudo pacman -S archlinux-keyring
sudo pacman -Su
Troubleshoots
Information for Catalyst users
If you are using an AMD card with Catalyst it is STRONGLY RECOMMENDED to use pacman for this update!!! The new style how Catalyst works now, would be this:
Catalyst-Utils needs now three new packages: catalyst-video, catalyst-input and catalyst-server.
Catalyst-Video provides some needed drivers like Intel and Vesa, since we have some hybrid systems too
Catalyst-Input provides the needed input drivers
Catalyst-Server provides the compatible Xorg-Server
Without these packages it would be not possible to still provide Catalyst at all. So it is logical to remove conflicting packages on these AMD systems. It can be tested with a new dev-build. If there are still issues regarding Catalyst, open an issue or a new thread, so we can discuss it.
Disable random mac address for your WLAN
Use nmcli to set 802-11-wireless.mac-address-randomization to never on a per connection basis or set
[device]
wifi.scan-rand-mac-address=no
in /etc/NetworkManager/NetworkManager.conf to disable the feature completely.
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
We support now several different steam-clients:
steam-manjaro: is our definition how steam should work on Manjaro.
steam-native: is our definition how steam should be used with our native libraries
steam: is the upstream client by Archlinux
steam-native-runtime: is the addon by upstream Archlinux to use native libraries
The clients by Manjaro are better tested and prefered for Manjaro Linux. However the upstream versions might also work for you.
Reference: Archlinux wiki
Current supported kernels
Linux310 3.10.104
Linux312 3.12.67
Linux316 3.16.38
Linux318 3.18.43
Linux41 4.1.34
Linux44 4.4.31
Linux47 4.7.10 [EOL]
Linux48 4.8.7
Linux49 4.9rc4
Linux-RT-LTS 4.4.27_rt37
Linux-RT 4.8.4_rt3
Package Changes
stable community i686: 157 new and 150 removed package(s)
stable community x86_64: 160 new and 153 removed package(s)
stable core i686: 9 new and 8 removed package(s)
stable core x86_64: 9 new and 8 removed package(s)
stable extra i686: 407 new and 406 removed package(s)
stable extra x86_64: 407 new and 406 removed package(s)
stable multilib x86_64: 2 new and 2 removed package(s)
Quelle
Re: 2016-11-11 - Cinnamon 3.2, Gnome 3.22.3, KDE Apps 16.08.3, (Stable Update)
Ohne Probleme!
System:    Host: dirk-pc Kernel: 4.8.7-1-MANJARO x86_64 (64 bit)
enrico_zh
Beitrag von enrico_zh »
Guten Abend,
bei mir ging das Update nicht. Es kam folgende Meldung:
(106/106) Prüfe Schlüssel im Schlüsselring         [######################] 100%
(106/106) Überprüfe Paket-Integrität               [######################] 100%
(106/106) Lade Paket-Dateien                       [######################] 100%
(106/106) Prüfe auf Dateikonflikte                 [######################] 100%
Fehler: Konnte den Vorgang nicht durchführen (In Konflikt stehende Dateien)
pacman-mirrorlist: /etc/pacman.d/mirrors/Africa existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Australia existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Austria existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Belarus existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Belgium existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Brasil existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Bulgaria existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Canada existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Chile existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/China existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Colombia existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Costa_Rica existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Czech existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Denmark existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Ecuador existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/France existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Germany existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Greece existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Indonesia existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Ireland existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Italy existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Japan existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Netherlands existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Philippines existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Poland existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Portugal existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Romania existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Russia existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Singapore existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Sweden existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Taiwan existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Turkey existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/United_Kingdom existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/United_States existiert im Dateisystem
pacman-mirrorlist: /etc/pacman.d/mirrors/Vietnam existiert im Dateisystem
pacman-mirrorlist: /usr/bin/pacman-mirrors existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors-2.0-py3.5.egg-info/PKG-INFO existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors-2.0-py3.5.egg-info/SOURCES.txt existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors-2.0-py3.5.egg-info/dependency_links.txt existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors-2.0-py3.5.egg-info/not-zip-safe existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors-2.0-py3.5.egg-info/top_level.txt existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__init__.py existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/__init__.cpython-35.opt-1.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/__init__.cpython-35.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/custom_help_formatter.cpython-35.opt-1.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/custom_help_formatter.cpython-35.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/i18n.cpython-35.opt-1.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/i18n.cpython-35.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/pacman_mirrors.cpython-35.opt-1.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/pacman_mirrors.cpython-35.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/pacman_mirrors_gui.cpython-35.opt-1.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/__pycache__/pacman_mirrors_gui.cpython-35.pyc existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/custom_help_formatter.py existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/i18n.py existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/pacman_mirrors.py existiert im Dateisystem
pacman-mirrorlist: /usr/lib/python3.5/site-packages/pacman_mirrors/pacman_mirrors_gui.py existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/bg/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/ca/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/cs/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/cy/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/de/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/el/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/es/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/es_419/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/fr/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/hr/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/is/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/is_IS/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/it/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/lt/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/ru_RU/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/sk/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/sv/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/tr/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/tr_TR/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/uk/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
pacman-mirrorlist: /usr/share/locale/uk_UA/LC_MESSAGES/pacman_mirrors.mo existiert im Dateisystem
Was ist das Problem?
Problem gelöst:
pacman -Sy --force pacman-mirrorlist
Danach ganz normal das Update starten.
Danke BLUERIVER, Update hat funktioniert.
Zuletzt geändert von enrico_zh am Samstag 12. November 2016, 23:24, insgesamt 1-mal geändert.
Manjaro, MX16, LMDE, YACY, Diaspora
Hallo enrico_zh,
bevor du dein Update startest gib mal folgendes im Terminal ein.
