coming closer to our next stable release we adjusted some packages. With this update pack we have the final v4.8 kernel added to our repositories. Some work went into our OpenRC packages. As usual we also provide the upstream updates, such as python2, packagekit and multimedia codecs.
Archlinux upstream fixes are now from: Mon Oct 03 10:57 CEST 2016
Please report any issues you may have with this update. Also read our troubleshoots to avoid known issues. Packages for our next stable review can be found here.
Kind regards,
Troubleshoots
Information for Catalyst users
If you are using an AMD card with Catalyst it is STRONGLY RECOMMENDED to use pacman for this update!!! The new style how Catalyst works now, would be this:
Catalyst-Utils needs now three new packages: catalyst-video, catalyst-input and catalyst-server.
Catalyst-Video provides some needed drivers like Intel and Vesa, since we have some hybrid systems too
Catalyst-Input provides the needed input drivers
Catalyst-Server provides the compatible Xorg-Server
Without these packages it would be not possible to still provide Catalyst at all. So it is logical to remove conflicting packages on these AMD systems. It can be tested with a new dev-build. If there are still issues regarding Catalyst, open an issue or a new thread, so we can discuss it.
Disable random mac address for your WLAN
Use nmcli to set 802-11-wireless.mac-address-randomization to never on a per connection basis or set
[device]
wifi.scan-rand-mac-address=no
Issues with updating MATE
LibreOffice and GTK3
GTK3
ufw
steam
Current supported kernels
Linux310 3.10.103
Linux312 3.12.63
Linux314 3.14.79 [EOL]
Linux316 3.16.37
Linux318 3.18.41
Linux41 4.1.32
Linux44 4.4.23
Linux46 4.6.7 [EOL]
Linux47 4.7.6
Linux48 4.8.0
Linux-RT-LTS 4.4.21_rt30
Linux-RT 4.6.7_rt14
Package Changes
testing community i686: 26 new and 21 removed package(s)
testing community x86_64: 26 new and 21 removed package(s)
testing core i686: 4 new and 4 removed package(s)
testing core x86_64: 4 new and 4 removed package(s)
testing extra i686: 29 new and 29 removed package(s)
testing extra x86_64: 29 new and 29 removed package(s)
testing multilib x86_64: 4 new and 1 removed package(s)
Quelle
