Seit dem letzten Update brauchen Firefox, Thunderbird und LibreOffice sehr lange beim Starten.
Firefox 114.0.1 braucht 28 Sekunden.
Thunderbird 102.12.0 28 Sekunden.
LibreOffice 7.4.7-2 48 Sekunden.
Terra Mini PC i7 mit Manjaro xfce
[manterra@manterra-terrapc ~]$ uname -a
Linux manterra-terrapc 6.1.31-2-MANJARO #1 SMP PREEMPT_DYNAMIC Sun Jun 4 12:31:46 UTC 2023 x86_64 GNU/Linux
[manterra@manterra
[manterra@manterra-terrapc ~]$ firefox
ATTENTION: default value of option mesa_glthread overridden by environment.
Sandbox: attempt to open unexpected file /sys/devices/system/cpu/cpu0/cache/index2/size
Sandbox: attempt to open unexpected file /sys/devices/system/cpu/cpu0/cache/index3/size
Sandbox: attempt to open unexpected file /sys/devices/system/cpu/present
Sandbox: attempt to open unexpected file /sys/devices/system/cpu/possible
[manterra@manterra-terrapc ~]$ thunderbird
[ImapModuleLoader] Using nsImapService.cpp
[NntpModuleLoader] Using NntpService.jsm
[Pop3ModuleLoader] Using Pop3Service.jsm
[calBackendLoader] Using Thunderbird's ical.js backend
console.debug: "Found 0 public keys and 0 secret keys (0 protected, 0 unprotected)"
console.warn: services.settings: Failed to load last_modified.json: TypeError: NetworkError when attempting to fetch resource.
console.debug: "Trying to load /usr/lib/thunderbird/libotr.so"
console.debug: "Trying to load libotr.so from system's standard library locations"
console.debug: "Trying to load libotr.so.5 from system's standard library locations"
console.log: (new Error("Cannot load required OTR library", "resource:///modules/OTRLib.jsm", 109))
console.error: carddav.sync: "Sync with server failed."
JavaScript error: resource:///modules/CardDAVDirectory.jsm, line 238: NS_ERROR_FAILURE: Incorrect response from server: 412 412
mriahi
