Host is Windows 10 1909, das Ganze hat schon mal wunderbar funktioniert, aber irgendwas ist durch Update auf neue VirtualBox Version 6.1.12 und neuen Kernel 5.4.58-1-MANJARO kaputtgegangen.
lsmod | grep vbox
vboxvideo 40960 1
drm_vram_helper 20480 1 vboxvideo
drm_kms_helper 221184 1 vboxvideo
drm 520192 6 drm_kms_helper,drm_vram_helper,vboxvideo,ttm
vboxsf 40960 0
vboxguest 45056 6 vboxsf
systemctl status vboxservice
● vboxservice.service - VirtualBox Guest Service
Loaded: loaded (/usr/lib/systemd/system/vboxservice.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2020-08-22 16:34:23 CEST; 2min 27s ago
Process: 284 ExecStartPre=/usr/bin/modprobe vboxguest (code=exited, status=0/SUCCESS)
Process: 285 ExecStartPre=/usr/bin/modprobe vboxvideo (code=exited, status=0/SUCCESS)
Process: 286 ExecStartPre=/usr/bin/modprobe vboxsf (code=exited, status=0/SUCCESS)
Main PID: 290 (VBoxService)
Tasks: 9 (limit: 2370)
Memory: 2.2M
CGroup: /system.slice/vboxservice.service
└─290 /usr/bin/VBoxService -f
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.836523 main OS Product: Linux
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.836730 main OS Release: 5.4.58-1-MANJARO
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.836970 main OS Version: #1 SMP PREEMPT Tue Aug 11 15:46:30 UTC 2020
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.837316 main Executable: /opt/VBoxGuestAdditions-6.1.12/sbin/VBoxService
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.837317 main Process ID: 290
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.837317 main Package type: LINUX_64BITS_GENERIC
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.838895 main 6.1.12 r139181 started. Verbose level = 0
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.839537 main vbglR3GuestCtrlDetectPeekGetCancelSupport: Supported (#1)
Aug 22 16:34:23 vAnt VBoxService[290]: 14:34:23.846258 automount Error: vbsvcAutomounterMountIt: Failed to mount 'Exchange' on '/media/sf_Exchange' because it is probably mounted elsewhere arleady! (-1,22)
Aug 22 16:34:24 vAnt VBoxService[290]: 14:34:24.849528 automount Error: vbsvcAutomounterMountIt: Failed to mount 'Exchange' on '/media/sf_Exchange' because it is probably mounted elsewhere arleady! (-1,22)
Was läuft hier schief?
Jan
