Repository Thema ist als GELÖST markiert
- CPU: AMD Ryzen 5 2400 G
- GPU: HD
- Kernel: 5.x
- Desktop-Variante: Mate
- GPU Treiber: radeon
- Hat sich bedankt: 5 Mal
- Danksagung erhalten: 2 Mal
- GPU: HD
- Kernel: 5.x
Re: Repository
Auf der Festplatteninstallation/Virtualbox guest sind nicht alle Repositories enthalten.
Welche Repositories gibt es?
Re: Repository
Hallo Popelmaniac,
für stable
* core
* extra
* community
* multilib
reicht auch ein Blick in die /etc/pacman.conf
Zum Rest:
https://wiki.archlinux.org/index.php/Of ... positories
für stable
* core
* extra
* community
* multilib
Zum Rest:
- GPU: HD
- Kernel: 5.x
- CPU: AMD Ryzen 3 2200G
- GPU: Prozessorintern
- Kernel: 6.1.53-1
- GPU Treiber: keinen
- Hat sich bedankt: 26 Mal
- Danksagung erhalten: 14 Mal
- GPU: HD
- Kernel: 5.x
- Kernel: 6.1.53-1
Re: Repository
Vielleicht hlft dir das weiter:
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
# can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir = /
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#TotalDownload
CheckSpace
#VerbosePkgLists
# REPOSITORIES
# [repo-name]
[core]
[extra]
[community]
[multilib]
#[custom]
- GPU: HD
- Kernel: 5.x
- GPU: HD
- Kernel: 5.x
Re: Repository
Ich hatte die packageslist so gedownloaded
dabei kam es während des entpacken
tar -xvzf '/home/andy/paketname.tar.gz'
gzip: stdin: not in gzip format
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Wo muss ich eine nicht korrupte packages.list downloaden?
Re: Repository
Hallo Popelmaniac,
irgendwas ist an deinem Profil verkehrt, da steht, daß Du seit 01.12.2018 dabei bist, muss ja wohl ein Druckfehler sein
https://wiki.manjaro.org/Pacman-mirrors ... g_defaults
Popelmaniac hat geschrieben: ↑Montag 4. Mai 2020, 06:18 Wo muss ich eine nicht korrupte packages.list downloaden?
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
- GPU: HD
- Kernel: 5.x
Re: Repository
Ich soll hier weitermachen
Ich möchte
http://ftp.halifax.rwth-aachen.de/manja ... repo/$arch
als mirror integrieren
Wie macht man das?
Ich möchte
Wie macht man das?
Re: Repository
Hallo Popelmaniac,
da hast Du dann auch Aachen, wenn es eh nicht schon dabei war.
Aber zwei Anfragen:
1. was treibst Du hier, was soll das werden? Was die Pakete betrifft ist es letztendlich egal, welche Mirrors Du benutzt. Gut, einer aus Australien ist wahrscheinlich etwas langsamer bei dir als einer aus Deutschland, aber sonst...
2. Verrate mal, ob Du halbwegs englische Seiten lesen kannst. Nicht daß ich hier ständig auf was verlinke, mit dem Du nichts anfangen kannst.
Popelmaniac hat geschrieben: ↑Montag 4. Mai 2020, 16:48 Ich möchte
sudo pacman-mirrors --country Germany && sudo pacman -Syyu
Aber zwei Anfragen:
- Hat sich bedankt: 63 Mal
Re: Repository
Hallo Popelmaniac
Dieses Forum lebt von der Zusammenarbeit.
Langsam bekommt man den eindruck mangelder Zusammenarbeit.
Etwas nicht zu Wissen ist kein makel und auch kein Problem.
Kleiner Hinweis:
Manjaro beruht auf Arch Linux
Arch Linux befehle gelten auch in Manjaro.
Das nötigste kannst du hier nachlesen:
https://wiki.archlinux.de/title/Pacman
Kleiner Hinweis:
