2017-09-08 2017-09-08 - Mesa, Kernels, PulseAudio, LibreOffice, (Stable Update)
Themen Author - Moderator
- Kernel: 6.12
- Hat sich bedankt: 31 Mal
Hi community,
with the huge Perl rebuild, Perl uses now the new toolchain and binary modules got moved to versioned path plus a hook to warn about outdated modules on update got added. Also we have now the final release of kernel v4.13 plus updated other kernel series as well. Latest LibreOffice, KDE Apps v17.08.1, Cinnamon v3.4.6 and Pulseaudio v11.0 refreshes some our editions.
More fixes went to our Mesa-Stack to stabilize KDE even more. We also worked on the new LTS-Kernel v4.14 added needed fixes to Calamares.
Current supported Kernels
linux310 3.10.107
linux312 3.12.74 [EOL]
linux316 3.16.47
linux318 3.18.70 [EOL]
linux41 4.1.43
linux44 4.4.87
linux48 4.8.17 [EOL]
linux49 4.9.48
linux410 4.10.17 [EOL]
linux411 4.11.12 [EOL]
linux412 4.12.11
linux413 4.13.0
linux414 4.14-rc0 (x86_64)
linux-RT-LTS 4.9.47_rt37 (x86_64)
linux-RT 4.11.12_rt13 (x86_64
Package Updates (Fri Sep 8 07:30:11 CEST 2017)
stable community i686: 487 new and 481 removed package(s)
stable community x86_64: 525 new and 518 removed package(s)
stable core i686: 20 new and 20 removed package(s)
stable core x86_64: 22 new and 20 removed package(s)
stable extra i686: 754 new and 747 removed package(s)
stable extra x86_64: 770 new and 747 removed package(s)
stable multilib x86_64: 13 new and 13 removed package(s)
[url=http://Quelle
linux310 3.10.107
linux316 3.16.47
linux41 4.1.43
linux44 4.4.87
linux49 4.9.48
linux412 4.12.11
linux413 4.13.0
[url=http://Quelle
Zuletzt geändert von Blueriver am Freitag 8. September 2017, 22:04, insgesamt 1-mal geändert.
- Neues Foren Mitglied
Re: 2017-09-08 - TBD (Stable Update)
Hallo.
Läuft alles Tadellos auf meinem KDE PC mit Linux Kernel 4.13!ÂÂ
- Kernel: 5.15 / 6.0
- GPU Treiber: Intel i915
- Hat sich bedankt: 15 Mal
- Danksagung erhalten: 36 Mal
Alles gut.
Manjaro 17.0.4 Gellivara
Kernel: x86_64 Linux 4.13.0-1-MANJARO
Sei klug und stell Dich dumm.
EDV = Ende der Vernunft!
- Kernel: 6.12
Ohne Probleme!
System:  Host: dirk-pc Kernel: 4.13.0-1-MANJARO x86_64 (64 bit)
     Desktop: Xfce 4.12.4 Distro: Manjaro Linux
Zuletzt geändert von Blueriver am Freitag 8. September 2017, 22:11, insgesamt 1-mal geändert.
- Kernel: 510
- Hat sich bedankt: 51 Mal
- Danksagung erhalten: 12 Mal
Re: 2017-09-08 2017-09-08 - Mesa, Kernels, PulseAudio, LibreOffice, (Stable Update)
Update lief ohne Probleme auf allen meinen aktiven Rechnern. Habe anschließend auf Kernel 413 umgestellt - auch das lief sauber durch. Herzlichen Dank an das Manjaro-Team!
p.s.
hat sich erledigt. spiegelserver mal aufgefrischt und dann kam es endlich. ;-)
kernel 4.13Â rennt gut , und auch sonst offenbar wieder ein sauberes und gelungenes update.
danke und grüße an das manjaro team.
schade. bisher kam und kommt hier nichts an, bzw wird nichts vom updater angeboten.
kein 4.13 kernel usw.  :-(
per terminal angestossen, und eben in pamac... nichts :-(
Zuletzt geändert von Quinix am Montag 11. September 2017, 00:40, insgesamt 1-mal geändert.
- Kernel: 510
Es lief doch nicht alles klar; nur eine lästige Kleinigkeit: Unter Mate funktioniert Autokey nicht mehr.
- Kernel: 510
Ich habe noch ein wenig herumgetüftelt und es hat sich gezeigt, dass Autokey nicht mit dem Kernel 4.13 arbeitet. Mit 4.12 funktioniert alles.
