Systemabstürze
Fangi
CPU: Ryzen 2700
GPU: Radeon RX-580
Kernel: 5.15, 6.1, 6.6, 6.12.17-1 LTS
Desktop-Variante: X-Cinnamon
GPU Treiber: Mesa 24.3.4-arch 1.1 radv
Hat sich bedankt: 21 Mal
Danksagung erhalten: 4 Mal
Re: Systemabstürze
Beitrag von Fangi »
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.6-x86_64
    root=UUID=722e0161-9e30-4aaf-b3a8-691ad17f542c rw quiet apparmor=1
    security=apparmor resume=UUID=5e3c5aa1-d43a-479b-b97c-320ca1a18827
    udev.log_priority=3
  Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1
    with: cairo-dock tools: avail: cinnamon-screensaver dm: LightDM v: 1.32.0
    Distro: Manjaro base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7A35 v: 1.0 serial: N/A
  Mobo: Micro-Star model: X370 GAMING M7 ACK (MS-7A35) v: 1.0 serial: N/A
    uuid: 00000000-0000-0000-0000-309c234b12f3 UEFI: American Megatrends LLC.
    v: 1.H4 date: 05/18/2023
Battery:
  Device-1: hidpp_battery_0 model: Logitech MK700 serial: <filter>
    charge: 70% (should be ignored) rechargeable: yes status: discharging
Memory:
  System RAM: total: 32 GiB available: 31.26 GiB used: 3.77 GiB (12.1%)
  Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None
    max-module-size: 32 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: CP16G4DFRA32A.C8FF serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR4 detail: synchronous unbuffered
PCI Slots:
  Slot: 0 type: PCIe lanes: 16 status: in use info: J6B2 length: long
    volts: 3.3 bus-ID: 00:01.0
  Slot: 1 type: PCIe lanes: 1 status: in use info: J6B1 length: short
    volts: 3.3 bus-ID: 00:1c.3
  Slot: 2 type: PCIe lanes: 1 status: in use info: J6D1 length: short
    volts: 3.3 bus-ID: 00:1c.4
  Slot: 3 type: PCIe lanes: 1 status: in use info: J7B1 length: short
    volts: 3.3 bus-ID: 00:1c.5
  Slot: 4 type: PCIe lanes: 1 status: in use info: J8B4 length: short
    volts: 3.3 bus-ID: 00:1c.6
  Slot: 5 type: PCIe lanes: 1 status: in use info: J8D1 length: short
    volts: 3.3 bus-ID: 00:1c.7
  Slot: 6 type: PCI bits: 32 status: in use info: J8B3 length: short
    volts: 3.3 bus-ID: 00:1e.0
  Slot: 7 type: PCIe lanes: 16 status: in use info: J10 length: short
    volts: 3.3 bus-ID: 00:03.1 children: 1: 27:00.0 class-ID: 0300 type: display
    2: 27:00.1 class-ID: 0403 type: audio
  Slot: 8 type: PCIe lanes: 8 status: available info: J3600 length: short
    volts: 3.3 bus-ID: 00:1f.7
  Slot: 32 type: PCIe lanes: 4 status: other info: J3707 length: short
  Slot: 2 type: PCIe lanes: 4 status: in use info: J3700 length: short
    volts: 3.3 bus-ID: 20:04.0
  Slot: 3 type: PCIe lanes: 1 status: available info: J3702 length: short
  Slot: 4 type: PCIe lanes: 1 status: available info: J3703 length: short
  Slot: 5 type: PCIe lanes: 1 status: in use info: J3701, M.2 length: short
    volts: 3.3 bus-ID: 20:01.0
CPU:
  Info: model: AMD Ryzen 7 2700 socket: AM4 bits: 64 type: MT MCP arch: Zen+
    gen: 2 level: v3 note: check built: 2018-21 process: GF 12nm
    family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 1550 min/max: 1550/3200 boost: enabled
    base/boost: 3200/4100 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.0 V ext-clock: 100 MHz cores: 1: 1550 2: 1550 3: 1550 4: 1550
    5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550 13: 1550
    14: 1550 15: 1550 16: 1550 bogomips: 102251
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: itlb_multihit status: Not affected
  Type: l1tf status: Not affected
  Type: mds status: Not affected
  Type: meltdown status: Not affected
  Type: mmio_stale_data status: Not affected
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spec_rstack_overflow mitigation: Safe RET
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via
    prctl
    sanitization
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DVI-D-1 bus-ID: 27:00.0
    chip-ID: 1002:67df class-ID: 0300 temp: 42.0 C
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
    s-diag: 583mm (22.95")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) E2290
    serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
    chroma: red: x: 0.631 y: 0.349 green: x: 0.341 y: 0.624 blue: x: 0.153
    y: 0.055 white: x: 0.314 y: 0.329 size: 477x268mm (18.78x10.55")
    diag: 547mm (21.5") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
  Monitor-2: HDMI-A-2 mapped: HDMI-A-1 pos: primary model: Seiko Epson PJ
    serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 30 gamma: 1.2 chroma:
    red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059
    white: x: 0.314 y: 0.329 size: 1600x900mm (62.99x35.43") modes: 1920x1200,
    1920x1080, 1600x1200, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
    1280x960, 1366x768, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 LLVM 16.0.6 DRM 3.54 6.6.19-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv
    v: 24.0.2-manjaro1.1 device-ID: 1002:67df surfaces: xcb,xlib
Audio:
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 27:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 29:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Texas Instruments PCM2902C Audio CODEC
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:5 chip-ID: 08bb:29c2 class-ID: 0300
  API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsactl,alsamixer,amixer
  Server-1: JACK v: 1.9.22 status: off tools: N/A
  Server-2: PipeWire v: 1.0.3 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
Network:
  Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 21:00.0 chip-ID: 1969:e0b1 class-ID: 0200
  IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global
    broadcast: <filter>
  IP v6: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: link
  Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 22:00.0
    chip-ID: 168c:003e class-ID: 0280
  IF: wlp34s0 state: up mac: <filter>
    broadcast: <filter>
  Info: services: NetworkManager,wpa_supplicant
  WAN IP: <filter>
Bluetooth:
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
    chip-ID: 0cf3:e300 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
  Device-2: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.2:5 chip-ID: 2357:0604
    class-ID: e001 serial: <filter>
  Report: ID: hci1 rfk-id: 1 state: up address: N/A
Logical:
  Message: No logical block device data found.
RAID:
  Message: No RAID data found.
Drives:
  Local Storage: total: 22.74 TiB used: 15.26 TiB (67.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 41.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 5d 17h cycles: 514
    read-units: 3,965,947 [2.03 TB] written-units: 5,760,549 [2.94 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
    model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
  SMART: yes health: PASSED on: 98d 20h cycles: 2,526
    read-units: 21,727,709 [11.1 TB] written-units: 25,886,518 [13.2 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD121KRYZ-01W0RB0 family: Gold size: 10.91 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: 1H01 temp: 34 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 146d 4h cycles: 2755
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    rpm: 7200 serial: <filter> fw-rev: 1H01 temp: 35 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 76d 1h cycles: 1565
  Optical-1: /dev/sr0 vendor: ATAPI model: iHAS324 F rev: CL8P
    dev-links: cdrom
  Features: speed: 48 multisession: yes audio: yes dvd: yes
    rw: cd-r,cd-rw,dvd-r state: running
  Optical-2: /dev/sr1 vendor: ASUS model: BC-12D2HT rev: 3.00 dev-links: N/A
    rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition:
  ID-1: / raw-size: 430.21 GiB size: 422.39 GiB (98.18%)
    used: 148.29 GiB (35.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 722e0161-9e30-4aaf-b3a8-691ad17f542c
  ID-2: /boot/efi raw-size: 620 MiB size: 618.8 MiB (99.80%)
    used: 292 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 75FA-7E23
  ID-3: /mnt/2. Speicherturm raw-size: 10.91 TiB size: 10.83 TiB (99.20%)
    used: 6.76 TiB (62.4%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
    maj-min: 8:17 label: 2. Speicherturm
    uuid: d8b695fb-3556-4b3d-a411-53fc9914fc5b
  ID-4: /mnt/Speicherturm raw-size: 10.91 TiB size: 10.83 TiB (99.20%)
    used: 8.36 TiB (77.2%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: Speicherturm uuid: 36f99ead-39cb-4e7f-9521-72939780d095
Swap:
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
    compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 5e3c5aa1-d43a-479b-b97c-320ca1a18827
Unmounted:
  ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 512 MiB fs: vfat label: N/A
    uuid: C953-AAA4
  ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 465.26 GiB fs: ext4 label: N/A
    uuid: 3b4c77d9-37d1-4540-abdc-7a6622a7bba6
USB:
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-2: 1-8:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
    chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-8.1:4 info: Logitech Logi Bolt Receiver
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c548 class-ID: 0300
  Device-2: 1-8.2:5 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Device-3: 1-8.4:8 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-4: 1-14:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-4: 2-8:2 info: Genesys Logic Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
    class-ID: 0900
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
    class-ID: 0900
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
    class-ID: 0900
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
    class-ID: 0900
  Hub-8: 5-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
    class-ID: 0900
  Device-1: 5-1.2:4 info: Xenta 2.4GHz Receiver (Keyboard and Mouse)
    type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA
    chip-ID: 1d57:32da class-ID: 0300
  Hub-9: 5-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
    chip-ID: 05e3:0608 class-ID: 0900
  Hub-10: 5-3.4:6 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 5-3.4.4:7 info: Logitech Unifying Receiver type: mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
    chip-ID: 046d:c52f class-ID: 0300
  Device-2: 5-4:5 info: Texas Instruments PCM2902C Audio CODEC
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-11: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-12: 6-1:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
    class-ID: 0900
Sensors:
  System Temperatures: cpu: 49.6 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 208
Repos:
  Packages: pm: pacman pkgs: 1944 libs: 513 tools: pamac,yay pm: flatpak
    pkgs: 0
  Active pacman repo servers in: /etc/pacman.d/mirrorlist
    1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    4: https://manjaro.kurdy.org/stable/$repo/$arch
    5: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    6: https://mirror.23m.com/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 399
  1: cpu: 7.1% command: thunderbird pid: 3205 mem: 587.9 MiB (1.8%)
  2: cpu: 4.1% command: electron pid: 3466 mem: 288.1 MiB (0.9%)
  3: cpu: 2.9% command: gnome-terminal-server pid: 4139 mem: 41.3 MiB (0.1%)
  4: cpu: 2.2% command: cinnamon pid: 1988 mem: 239.4 MiB (0.7%)
  5: cpu: 1.6% command: firefox pid: 2600 mem: 580.6 MiB (1.8%)
  Memory top: 5 of 399
  1: mem: 587.9 MiB (1.8%) command: thunderbird pid: 3205 cpu: 7.1%
  2: mem: 580.6 MiB (1.8%) command: firefox pid: 2600 cpu: 1.6%
  3: mem: 463.0 MiB (1.4%) command: telegram-desktop pid: 3574 cpu: 0.1%
  4: mem: 303.9 MiB (0.9%) command: electron pid: 3453 cpu: 1.1%
  5: mem: 288.1 MiB (0.9%) command: electron pid: 3466 cpu: 4.1%
Info:
  Processes: 399 Power: uptime: 35m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.5 GiB services: csd-power,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Sudo (sudo) v: 1.9.15p5
    default: Bash v: 5.2.26 running-in: gno
Bei Handbrake finde ich die Logs nur im laufenden Betrieb, danach werden die wohl einfach überschrieben. Aber die Abstürze sind eh nicht auf Handbrake beschrängt, oft friert der Desktop bereits im hochfahren ein und mündet dann im beschriebenen Blackscreen. Aber mit Handbrake bekomme ich den Rechner fast sicher zum Absturz. Heute konnte ich mit Handbrake arbeiten, allerdings hatte ich vorher alle anderen Anwendungen geschlossen. Evtl. ist meine Samsung M2-SSD zu alt? Auch frage ich mich gerade, ob es bei einer evtl. Neu-Installation mit einer neuen SSD und 32GB RAM eigentlich sinnvoll ist eine SWAP-Partion einzurichten. Habe jedenfalls gerade swapiness von 60 auf 10 reduziert und beobachte das dann mal einige Tage.
Danksagung erhalten: 578 Mal
Re: Systemabstürze
Hallo Fangi,
Fangi hat geschrieben: ↑Mittwoch 20. März 2024, 22:38 Bei Handbrake finde ich die Logs nur im laufenden Betrieb
Handbrake legt eine Logdatei in deinem Homeverzeichnis an. Es würde mich wundern, wenn die beim Neustart gelöscht wird. Vielleicht gibt es dort hilfreiche Infos (s. dazu https://handbrake.fr/docs/en/latest/hel ... y-log.html)
Aber wenn ich lese, dass es auch an anderer Stelle immer Abstürze gibt, habe ich Zweifel ob Handbrake die Ursache ist. Was SWAP betrifft, ich sage mal so, SWAP anlegen ist nie verkehrt. Zumindest kann man bei solchen undurchsichtigen Abstürzen dann ausschliessen, dass es am fehlenden SWAP liegt.
Hat sich bedankt: 183 Mal
Danksagung erhalten: 319 Mal
Re: Systemabstürze
Fangi hat geschrieben: ↑Mittwoch 20. März 2024, 22:38 Evtl. ist meine Samsung M2-SSD zu alt? Auch frage ich mich gerade, ob es bei einer evtl. Neu-Installation mit einer neuen SSD und 32GB RAM eigentlich sinnvoll ist eine SWAP-Partion einzurichten. Habe jedenfalls gerade swapiness von 60 auf 10 reduziert und beobachte das dann mal einige Tage.
Nein, ich glaube nicht das es an der SSD liegt, eher an der Installation.
Ich habe die Erfahrung gemacht das oft das Ram einen weg hat. Ich nehme mal an das du zwei Riegel hast, einen einfach mal rausnehmen. Wenns weiterhin Abstürze gibt, den anderen nehmen. Wenn du vier Riegel hast kannst du es auch mal nur mit einem testen, solange bis du den defekten hast ... wenn es denn daran liegt.
Du kannst auch mal mit einen Installations/Live - Medium hochfahren und dort temporär Handbrake installieren.
Wenns dann immer noch abstürzt, isses definitiv die Hardware.
Wenn nicht, ist eine Neuinstallation ratsam.
Wenn du Bedenken hast das es doch die SSD ist, kauf dir halt ne neue. 250GB bekommt man unter 20€. Wenn dir 120GB reichen, die gibt es schon ab 12€
Kann natürlich auch am Mainboard liegen, k.A. ob man das irgendwie im laufendem System testen kann.
Und, aber das ist nur meine Meinung, mit 32GB unter Linux wird kein Swap benötigt. Das braucht man nur wenn der Ruhemodus/Ruhezustand benutzt wird.
Andererseits, wenn du aufwendige Grafik/Video - Anwendungen fährst, (nicht Handbrake!) können auch 32GB zu wenig sein. Aber das ist äußerst selten der Fall.
Fangi
CPU: Ryzen 2700
GPU: Radeon RX-580
Re: Systemabstürze
Beitrag von Fangi »
Die zwei Ramriegel sind erst wenige Monate alt, könnte natürlich trotzdem einer defekt sein. Allerdings habe ich auf einer zweiten SSD noch ein Linux-Mint-System laufen welches ohne Ram-Partion auskommt und auch mit Handbrake rund läuft, also keine Systemausfälle. Auf der älteren SSD mit Manjaro sind jedenfalls bereits einige Bereiche, welche sich nicht mehr formatieren lassen außerdem habe ich bei der letzten Installation unüberlegterweise den Ruhemodus aktiviert. Lässt sich der nachträglich deaktiveren? Gestern und heute konnte ich mit Manjaro normal arbeiten und hatte jedenfalls keinerlei Probleme.
Allerdings habe ich gerade Corona und tierische Kopfschmerzen, daher verschiebe ich das Thema gerade möglichst, bis es mir wieder besser geht.
Re: Systemabstürze
Fangi hat geschrieben: ↑Donnerstag 21. März 2024, 20:42 Auf der älteren SSD mit Manjaro sind jedenfalls bereits einige Bereiche, welche sich nicht mehr formatieren lassen
Da hast du deine Antwort. Gibts nix mehr dazu zu sagen.
Fangi hat geschrieben: ↑Donnerstag 21. März 2024, 20:42 außerdem habe ich bei der letzten Installation unüberlegterweise den Ruhemodus aktiviert. Lässt sich der nachträglich deaktiveren?
Klar geht das. Hab zwar kein Cinnamon, aber da gibts auch was mit "Energieeinstellungen". Da kannst du das abschalten.
Der Swap geht dadurch allerdings nicht weg.
Fangi hat geschrieben: ↑Donnerstag 21. März 2024, 20:42 Allerdings habe ich gerade Corona und tierische Kopfschmerzen, daher verschiebe ich das Thema gerade möglichst, bis es mir wieder besser geht.
Das tut mir leid. Gute Besserung.
Fangi
CPU: Ryzen 2700
GPU: Radeon RX-580
Re: Systemabstürze
Beitrag von Fangi »
Von Corona bin ich jedenfalls schon wieder einige Zeit genesen. Alles in Allem läuft mein Rechner seid ich "swapiness" von original 60 auf 10 reduziert habe rund und hat kaum noch Ausfallerscheinungen. Auch mit Handbrake kann ich ganz normal arbeiten.
sudo sysctl vm.swappiness=10
Natürlich ist mir klar das meine Samsung M2-SSD beschädigt ist, aber ich fahre die jetzt so lange, bis es gar nicht mehr geht, habe einfach keine Lust immer neue Teile zu kaufen. Gerne hätte ich eine M2-SSD, bei der ich auch unter Linux möglichst einfach die Firmware aktualisiert bekomme.
