[Stable Update] 2021-03-18 - Kernels, Plasma, Frameworks, LibreOffice, Firefox, Systemd
Hatte keine Probleme.
11
85%
2
15%
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 13
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
philm, post:1, topic:58581 hat geschrieben: Hello community,
Another **stable** branch update with some usual updates for you.
*We are happy to finally have our first release candidate ready. Download Ornara 21.0-rc1 from [here ](https://sourceforge.net/projects/manjar ... .0-210318/).*
Here a list of our regular updates with this **stable snap**:
* Most of the **Kernels** got updated
* **Thunderbird** is now at [78.8.1 ](https://www.thunderbird.net/en-US/thund ... easenotes/)
* New point-release of [KDE-Apps ](https://kde.org/announcements/releases/20.12.3/) got added
* **LibreOffice** pushed out another minor-releases: [7.0.5 ](https://blog.documentfoundation.org/blo ... ffice-705/), [7.1.1 ](https://blog.documentfoundation.org/blo ... ffice-711/)
* **Firefox** is now at [86.0.1 ](https://www.mozilla.org/en-US/firefox/8 ... easenotes/)
* We [updated ](https://gitlab.manjaro.org/packages/cor ... 145772b158) **grub** to [2.06-rc1 ](https://lists.gnu.org/archive/html/grub ... 00219.html)
* **Plasma** [5.21.3 ](https://kde.org/announcements/plasma/5/5.21.3/) got released yesterday
* **KDE Frameworks** are at [5.80.0 ](https://kde.org/announcements/frameworks/5/5.80.0/)
* **Systemd** is at [247.4 ](https://github.com/systemd/systemd-stab ... 3...v247.4), which also reduces boot-up times
* **gstreamer** got also updated
* Some updates to **Gnome**
* Clean-up of some 3rd-party **grub** packages
* Other regular upstream updates including **python** and **haskell**
Get our latest daily developer images now from Github: [Plasma ](https://github.com/manjaro-plasma/download/releases), [Gnome ](https://github.com/manjaro-gnome/download/releases), [XFCE ](https://github.com/manjaro-xfce/download/releases).
**Our current supported kernels**
* linux44 4.4.261
* linux49 4.9.261
* linux414 4.14.225
* linux419 4.19.180
* linux54 5.4.105
* linux59 5.9.16 [EOL]
* linux510 5.10.23
* linux511 5.11.6
* linux512 5.12-rc3
* linux54-rt 5.4.102_rt53
* linux59-rt 5.9.1_rt19
**Packages Changes** (Wed Mar 17 11:03:48 CET 2021)
* stable community x86_64: 1524 new and 1506 removed package(s)
* stable core x86_64: 50 new and 50 removed package(s)
* stable extra x86_64: 1124 new and 1277 removed package(s)
* stable kde-unstable x86_64: 334 new and 334 removed package(s)
* stable multilib x86_64: 31 new and 31 removed package(s)
A detailed list of all package changes can be found here (https://gitlab.manjaro.org/-/snippets/6 ... -03-18.txt).
Quelle
Sachse
Kernel: 5.10
Desktop-Variante: Xfce4 & KDE
GPU Treiber: Freier Treiber
Hat sich bedankt: 46 Mal
Danksagung erhalten: 51 Mal
Re: [Stable Update] 2021-03-18 - Kernels, Plasma, Frameworks, LibreOffice, Firefox, Systemd
Beitrag von Sachse »
Update ist soweit sauber durchgelaufen.
Ein Problem ergab sich jedoch mit dem Paket "electron9.4" aus dem AUR.
Das Paket wird von Balena-Etcher benötigt.
Ich habe keinen blassen Schimmer wie man "Builds" bearbeitet.
Kurzum habe ich mich von diesem Paket getrennt inkl. Balena Etcher.
Werde zukünftig Images auf USB/SD-Karten nur noch mit "dd" schreiben.
LG Sachse
Kernel: 6.1
Ohne Problem! :)
MichaelP
CPU: AMD Ryzen 9 5900X
GPU: NVIDIA GTX 3080 Ti
Kernel: 6.7.0
Desktop-Variante: KDE 5.27.10
GPU Treiber: NVIDIA 545.29.06
Hat sich bedankt: 17 Mal
Danksagung erhalten: 28 Mal
Beitrag von MichaelP »
Hallo Sachse,
Update (KDE) lief bei mir sauber durch. Hab mal nachgeschaut - hab kein "elekronx.x" .
(Balena) Etcher ist bei mir drin, allerdings als Etcher 1.5.116-1 (community) aus den offiziellen Softwarequellen installiert.
Elektron scheint dafür nicht erforderlich - oder braucht man das bei XFCE? ::)
Gruß Michael
Sachse
Kernel: 5.10
Hallo Michael,
danke für die Rückmeldung.
Beim deinstallieren von "electron9.4" wurde mir gleich die Abhänigkeit zu Balena-Etcher aufgezeigt.
Also "electron" weg = Balena weg.
Vielleicht hab ich eine komische Version von Balena installiert....versuche das jetzt noch einmal.
LG Sachse
So sieht das aus:
[lenovo@lenovo ~]$ pamac install balena-etcher
Warnung: balena-etcher ist nur vom AUR verfügbar
Vorbereitung...
Klone balena-etcher Build-Dateien...
fatal: Kein Git-Repository (oder irgendeines der Elternverzeichnisse): .git
Überprüfe balena-etcher Abhängigkeiten...
Klone electron9 Build-Dateien...
Überprüfe electron9 Abhängigkeiten...
Zu erstellen (2):
  electron9      9.4.4-2        AUR
  balena-etcher  2:1.5.116-1    AUR
Transaktion anwenden ? [e/j/N]
Das erstmal bis dahin - jetzt beginnt der Build-Prozess.
LG Sachse
Sachse hat geschrieben: ↑Freitag 19. März 2021, 14:14 ....Vielleicht hab ich eine komische Version von Balena installiert...
Bei Manjaro.org gibt es diverse Problemberichte im Zusammenhang mit dem Update und electron.
Wenn nur Balena-Etcher betroffen ist, kann man aber auch auf das Appimage von Balena-Etcher ausweichen.
Das Appimage ist ohnehin wesentlich schlanker als die 227MB Installation aus den Repos.
Sachse
Kernel: 5.10
Hier noch der Nachtrag vom Install Prozess
da werd einer schlau draus :)
Wie gesagt "dd" tut es ja auch.
LG Sachse
Kernel: 6.6 LTS
GPU Treiber: nVidia
Hat sich bedankt: 19 Mal
Danksagung erhalten: 106 Mal
Lief alles sauber durch!
@Sachse
MichaelP hatte doch geschrieben, dass er Etcher nicht aus dem AUR sondern aus den community Repos installiert hat.
Manchmal kommen die Programme auch in die offiziellen Repos, wenn sich Maintainer finden - war zuletzt bei mir mit Vivaldi der Fall.
MichaelP
Kernel: 6.7.0
Stimmt - z.B suchen in PAMAC nach "Etcher", nicht nach "Balena" :)
Gruß Michael
Jean-Paul
CPU: --
GPU: --
Kernel: --
Desktop-Variante: --
GPU Treiber: --
Hat sich bedankt: 42 Mal
Danksagung erhalten: 48 Mal
Beitrag von Jean-Paul »
Für das hier brauchte der Rechner gestern sage und schreibe von 11:10 bis 15:50 >:(
https://imgur.com/YO7qEMf.png
Und das obwohl ich vorher ein:
sudo pacman-mirrors -c Germany
durchgeführt hatte. Das gab es noch nie bei Manjaro. Und das bei einer Geschwindigkeit von 46.614 kbit/s.
Ich fühlte mich zurückversetzt zu Win10 Zeiten.... >:D
Seltsam das, ich hoffe das war nur einmalig. Ansonsten keine Probleme, System läuft.
Borrtux
GPU: NVIDIA GeForce 930M
Kernel: 5.10.18-1-MANJARO
Danksagung erhalten: 13 Mal
Beitrag von Borrtux »
LG Sachse
kann man das abbrechen?
Mein Build-Prozess ist bei 7000/32000 (ca)
Das kann noch lange dauern! ???
Es grüßt euch borrtux
nijila
CPU: AMD Ryzen 5 PRO 4650G
GPU: Integrated graphics – AMD Radeon RX Vega 7
Kernel: stable, actual
GPU Treiber: amdgpu
Hat sich bedankt: 16 Mal
Danksagung erhalten: 8 Mal
Beitrag von nijila »
Lief einwandfrei.
Funny fact / leicht offtopic, am gleichen Tag:
Firmen-Laptop:
9 Uhr: Win10-Update gestartet, bis 15 Uhr reiner Download durch überlastetes VPN
15 Uhr: Updatevorgang
23 Uhr: Update immer noch am Laufen. Verärgerter Abbruch durch mich durch Hard-Off, da ich Ruhe haben wollte (Lüfter auf 100% den ganzen Tag hat mir gereicht). Arbeiten war teilweise langsam, später sogar unmöglich
In der Zeit mein PC:
22 Uhr: Manjaro Update wird angezeigt, starte knapp 2 GB Download
22:05 Uhr: Updatevorgang
22:09 Uhr: Alles fertig, Neustart kein Muss, habs aber getan, weil ich noch was im BIOS nachsehen wollte
22:10 Uhr: fertig. Arbeit war bis auf 1min Neustart uneingeschränkt.
Das hat mich echt glücklich gemacht :)
Borrtux
Die eigentlichen Updates liefen gut.
1x Gnome auf VM ca. 830MB - lief problemlos durch.
1x KDE auf Laptop 1,2 GB lief auch problemlos durch.
Anschließend aber das Update aus dem AUR electron9
Hatte bevor ich mich informierte auf updaten geklickt. Und dann nahm die Katastrophe ihre Lauf.
Das Kompilieren hat viele Stunden gedauert. Abbrechen war nicht möglich (Abbruchknopf ausgegraut).
Dann ließ ich es über Nacht laufen. Habe aber nicht dran gedacht, dass meine Fritzbox nachts das W-Lan abschaltet (ist so gewollt).
Scheinbar brauch man beim Kompilieren das Internet. Frage: Ist das so?
Jedenfalls hat es am nächsten Tag auch noch mal Stunden gedauert.
Aber jetzt alles prima.
Currock
Kernel: 5.7.17-2-MANJARO
GPU Treiber: intel_agp,i915
Hat sich bedankt: 10 Mal
Beitrag von Currock »
Das Update ist eben erst (hatte ihn ein paar Tage nicht eingeschaltet) auf meinem 1. Hauptrechner durchgelaufen, ohne Probleme, alles funktioniert wie es soll.
Eine nicht ganz so wichtige Änderung gibts:
Mit den Arbeitsflächen-Effekten bei KDE hat es bis eben nicht so funktioniert, sie waren einfach nicht vorhanden.
Nach dem Update gibts wieder etwas mehr fürs Auge, die Effekte funktionieren. Auf diesem Rechner sowie auf 2 Notebooks.
Das Progrämmchen netmdcli zum Ansprechen von MiniDisks funktioniert auch wieder, es war ein paar Wochen "gestört", es hat das MiniDisk-Laufwerk nicht gefunden. Werde gleich eine Sicherung mit Timeshift erstellen und als funktionierend beschriften.
