2018-08-25 - Kernels, KDE Apps & Framework, Flatpak 1.0, Nvidia, (Stable Update)
Hatte keine Probleme.
1
100%
0
Keine Stimmen
0
Keine Stimmen
Insgesamt abgegebene Stimmen: 1
Kernel: 6.1
Hat sich bedankt: 28 Mal
Danksagung erhalten: 151 Mal
Hi community,
Welcome to another stable update. So what do we have with this one?
we updated most of our Kernels
we updated our Jade Desktop
we updated KDE Apps and KDE Framework
flatpak is now at 1.0
more qt4 packages got ditched
Gimp is now at 2.10.6
Ńvidia drivers got fixed in regard of an issue with libglvnd and updated to 396.54
we updated our Adapta-Themes
latest version of libssh
we added lutris to our repos
clipit should work again
we cleaned up some EOL kernels and unneeded kde-i18n packages
the usual upstream rebuilds/updates
We hope with all these changes Manjaro to be more efficient for you all.
Currently we are working on a new Manjaro-Hardware project, the Bladebook Fall 2018. It will be powered by Manjaro KDE v18.0 and the latest Intel Apollo Lake Quad-Core HD APU. Having a fanless metal material (cassis either silver or gold-rose) and eMMC as storage (additional M2-SSD possible), it will have a long battery life. Find out more on our hardware page.
If you are curious about the latest state of development for the upcoming Manjaro-Illyria 18.0 release, you now have the opportunity to download a beta-build
of Manjaro-Xfce 18.0 including the latest xfce-gtk3 packages aswell as our most recent styling efforts. Our KDE fans may try our beta-build with the latest KDE v5.13 instead. And our GNOME fans may try our beta-build with the latest GNOME v3.28.
Latest information about the intel-cpu-bug risk and our efforts can be found here.
Current supported Kernels
linux316 3.16.57
linux318 3.18.119 [EOL]
linux44 4.4.151
linux49 4.9.123
linux414 4.14.66
linux417 4.17.18
linux418 4.18.4
linux419 4.19-rc0
linux414-rt 4.14.52_rt34
linux416-rt 4.16.18_rt11
Quelle
Zuletzt geändert von Blueriver am Samstag 25. August 2018, 13:01, insgesamt 1-mal geändert.
Kernel: 4.20
Kernel: 6.1
Re: 2018-08-25 - Kernels, KDE Apps & Framework, Flatpak 1.0, Nvidia, (Stable Update)
Alles bestens!
Kernel: 4.20
Benutzer 118 gelöscht
Nachdem ich den Kernel 4.15 entfernt habe lief es ohne Probleme. :D
