QuelleHello i686ers!
Another huge set of updates, which once again brings Firefox and Chromium up-to-date.
Also of note is the KDE update to 5.13.1, as well as systemd 239.
There’s the usual set of Haskell and Python module updates.
Only kernel 4.14 updated in this set due to the GitLab migrations.
Anyone who would like to help out testing the upstream packages, please read the archlinux32 thread for details about how they automate their testing process and how to get involved:
https://bbs.archlinux32.org/viewtopic.php?id=171
(running this in an archlinux32 VM would be fine, there will hopefully be a way of doing this directly from within manjaro32 in the future)
Available kernels
Series Version
linux316 3.16.56
linux41 4.1.52
linux44 4.4.138
linux49 4.9.109
linux414 4.14.51
archlinux32
Why aren’t the available packages/package versions the same as x86_64?
archlinux32 packages are based on Arch packages but may need editing to build correctly. Builds of less-popular packages are lower priority.
Manjaro-specific packages may lag behind x86_64 because there aren’t as many packagers. If you notice an important package is lagging please report it; at the moment it’s only me packaging for i686:
Using manjaro32 and spotted an out-of-date Manjaro package? First, check the Manjaro GitHub sources for core, extra, and community. If it’s in the GitHub sources, it’s a Manjaro package. You can check whether the package is in the archlinux32 repos directly: https://mirror.archlinux32.org/i686/ Alternatively, check the Arch package list to see whether the package is one likely to be built by archlinux32. If it’s a Manjaro package, and it’s out-of-date, report here.
What about security updates?
What about installer images?
Phil very kindly updated the preview installer images:
osdn.net
Downloading File /xfce/17.1.7-rc1 - Manjaro Linux (32-Bit) - OSDN
Free download page for Project Manjaro Linux (32-Bit)'s 17.1.7-rc1.Manjaro is a user-friendly Linux distribution based on the independently developed Arch operating system. Within the Linux com...
Full list of changes
Full list is available here.
2018-07-03 - KDE, OpenJDK, Pulseaudio, GHC, Firefox, LibreOffice (Stable Update)
Themen Author - Moderator
- Kernel: 6.1
- Hat sich bedankt: 28 Mal
- Danksagung erhalten: 149 Mal
Kernel: 4.20
Kernel: 4.20
- Kernel: 510
- Hat sich bedankt: 42 Mal
- Danksagung erhalten: 11 Mal
Re: 2018-07-03 - KDE, OpenJDK, Pulseaudio, GHC, Firefox, LibreOffice (Stable Update)
Meinem Junkie-Anteil wurde nun Genüge getan ... Auf allen Rechnern liefen die Updates am Ende erfolgreich durch und alles ist gut. Vielen Dank!
Ein kleines Problem gab es bei meinen Rechnern mit XFCE-Oberfläche. Da wurde der Update-Prozess zunächst abgebrochen mit dem Hinweis, dass es eine bestimmte Datei im System schon gäbe. Da auch der Pfad in der Fehlermeldung stand, habe ich als root die Datei umbenannt, den Update-Prozess erneut angestoßen und alles war gut.
