Hello community,
We welcome 2020 with our second Testing Update!
Some feature-updates:
We some more patches to linux54
Updated some Gnome Apps
Reintroduced gconf to support some older applications
Added some more Haskell updates/rebuilds
Updated Pamac to 9.3 series, wich includes changes in the backend transaction process to make it more robust and stable.
The usual upstream fixes
If you like following latest Plasma development you may also like to check out our current version of manjaro-kde-dev 8, which we build on a regular basis against kde-git master packages. Also check out our current 18.1.5 ISOs 3 and give us the needed feedback.
As always we appreciate your input and feedback for the updates.
Upstream notice
Arch updated their default compression to zstd 5. We adopted to the same standard. More and more packages will have the zst extension from now on.
Our current supported kernels:
linux316 3.16.80
linux44 4.4.207
linux49 4.9.207
linux414 4.14.161
linux419 4.19.92
linux53 5.3.18 [EOL]
linux54 5.4.7
linux55 5.5-rc4
linux419-rt 4.19.90_rt35
linux54-rt 5.4.5_rt3
Package Changes (Sat Jan 4 09:41:54 CET 2020)
testing community x86_64: 505 new and 494 removed package(s)
testing core x86_64: 2 new and 2 removed package(s)
testing extra x86_64: 35 new and 35 removed package(s)
Quelle
[Testing Update] 2020-01-04 - Linux54, Gnome Apps, Pamac 9.3beta, Haskell
Themen Author - Administrator
- CPU: Intel® Core™ i7-2630QM
- GPU: Intel UHD Graphics
- Kernel: 5.6
- Hat sich bedankt: 189 Mal
